Ian.G's Track/Drift Levin.
03-11-2012, 01:31 PM
Post: #441
Ian.G Wrote:I think its probably an early JDM S13 disk - proving hard - maybe I will have to try and Email NAMS/Nagisa and see what they can do to help S13 always been drum&disc at the rear. If it's JDM and Nissan related the only disc that I could think of is from a Q-Model S14 (non turbo version) as they were 4lug too AE86 ex-daily |
03-11-2012, 04:58 PM
Post: #442
awesome mate
I'm so JDM I put everything sideways. AE86 owner |
03-12-2012, 09:50 AM
Post: #443
there are similar options here in australia... and they use the s13 disc as they dont use an internal drum brake. they utilise the same handbrake mechanism, ie caliper, as the ae86... the calipers from an s13 have ebrake connections, the later 5 stud s chassis stuff doesnt.
As aus never got the s13, its fair to say all our s13 information is jdm based. clutch kick, switch, tree .... oowwww |
03-12-2012, 10:47 AM
Post: #444
fantapants - that sounds like it could be the one - these dont appear to be designed for use with an internal drum mechanism for the hand brake - I'm using standard 86 rear calipers with the cable pulls.
So you maybe thing they are a rear disk of an early JDM 180sx ? Regards Ian. ![]() |
03-12-2012, 10:53 AM
Post: #445
Glad we have you back Ian.
![]() danielvanderwoude Wrote:looks like the nmwisima joke saved you in the end ![]() |
03-12-2012, 10:05 PM
Post: #446
Welcome back and great to see it finally will get back on the road!
![]() ![]() 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: ![]() |
03-13-2012, 03:03 PM
Post: #447
Delighted your back Ian i was getting worried this may have been a victim of the recession and would never be completed!
The discs are from the UK 200sx S13 BTW |
03-13-2012, 07:47 PM
Post: #448
Maurice Wrote:Delighted your back Ian i was getting worried this may have been a victim of the recession and would never be completed! Hi Maurice from the rear ? The ones I can find from the rear of an S13 200sx 89-94 are vented - these ones are solid Regards Ian. ![]() |
03-14-2012, 11:40 AM
Post: #449
Ian.G Wrote:fantapants - that sounds like it could be the one - these dont appear to be designed for use with an internal drum mechanism for the hand brake - I'm using standard 86 rear calipers with the cable pulls. its getting a bit beyond my pay grade ![]() Ajps in adelaide is sellling a fabricated mount adaptor to use the 86 brake caliper and the s13 sedan shell rotor. These didnt use an internal drum brake setup, at least not in any of the models that have been imported from japan. Fwiw i THOUGHT this was the case for all the 4 stud s'series the 5 stud changeover was when they went to internal drumbrake. Also for got to mention i really dig the car mate ![]() clutch kick, switch, tree .... oowwww |
03-14-2012, 06:42 PM
Post: #450
Ian.G Wrote:Maurice Wrote:Delighted your back Ian i was getting worried this may have been a victim of the recession and would never be completed! lm not sure ian il check when i go home if they are solid or vented, i got a pair from the rear of a a 90 uk S13 200sx from a friend that i didnt end up using but the stud pattern was exactly the same im sure they are soild but il let you know tomorrow ok |
Track AE86 Build from south america | Nurburgring | 3 | 8,176 |
Ae86 Levin drift project. | filip.alin | 7 | 9,841 |
86er's Track rebuild N2.??? Finally an update page 8 | 86er | 191 | 261,370 |
(AUS) 8age trueno track monster! | green_boy_91 | 48 | 57,742 |
KP61: The track fridge | 127 Boy | 20 | 30,796 |
