Ian.G's Track/Drift Levin.
01-17-2007, 10:08 PM
Post: #151
LOoking great Ian, Run free is hott Yummie! Yummie! Thumbs up!
sorry to hear about the dealy i know the feelin dont wory it will make it all more worth it in end Thumbs up!
[Image: AEU86 AE86 - Ian.G's Track/Drift Levin.]
01-28-2007, 04:09 PM
Post: #152
STILL waiting for my exhaust to arrive so no new fabrication has taken place.
Paz and I got our dashboards flocked via Dori Matt on driftworks. I always used to be distracted by the huge amount of glare you would get in the sun on these nasty old 80's dash coverings so it seemed like a good time to be rid of it.
Some of the prep work they do before the flocking process is also to clean up and cracks or blemishes - I had a hole in the top of my dash where the old aircon interior temp sensor used to go. That is now all filled in and the dash looks like new again.
take a peep
very very happy with how that has turned out.
does anyone know if the digital clock surround is still available as a part from toyota ? I cracked mine when I was stripping the dash down (plastic was sooooo brittle) - would be nice to replace it and keep the clock otherwise I will have to make up a small panel to cover it over.
Regards Ian.
01-28-2007, 05:29 PM
Post: #153
The sourarounding is still available I think, at least a yearago when I ve asked it was.
Still is very very easy to find one @ ebay
Its amazing the work done in your dash.
How much would something like that cost if I may ask?
[Image: AEU86 AE86 - Ian.G's Track/Drift Levin.] http://www.jdmbits.com
01-28-2007, 05:40 PM
Post: #154
hi nmwisima,
most rally preparation places will be able to perform the task of electro-static flocking - its very typical in rally and saloon racers.
I should cost between £80-150 depending upon who you use. If you cant find people locally there are places in the uk that can do it if you can cope without your dash for a few weeks.
Regards Ian.
01-28-2007, 05:45 PM
Post: #155
Something tells me its gona cost more than 300 eyros here in Greece...
02-03-2007, 10:18 PM
Post: #156
So - here is the nice carbon fibre back plate that I'll be using with the Jenvey ITBs I have for my F20 engine.
Once I've cut the back for the trumpets and their mounting points those lovely toot tooters will sit inside like so
Then a nice big ITG filter like this
to go over the top and thats that job sorted. No master cylinder clearance issues any more Thumbs up! with them being on the opposite side of the engine bay now
Centre console - I need to make a new one of these whcih will extend down to the base of the new transmission tunnel so I have somewhere to mount gauges, kill switch, fuse boxes, extinguisher pull etc. We will make a mockup in light alu sheet so then we can just use that as a tool to lay up the carbon for that too.
Also got a few of the bits my F20 motor was missing. Needed a new water pump and pully (missing from mine) and an Idler pully. Fortunately my friend is running a Davies Craig electric water pump on this s2000 powered westfield so the ones from his engine are now on mine.
Also - ordered some the final parts of my front end from SUMO POWER on friday - the following should be with me in 5-6 weeks. Hurray!
Nagisa Auto adjustable lower arms
Nagisa Auto inner steering knuckles
Nagisa Auto raised drivers floor with heel stops
right now I get all excited just thinking about driving it LOL.
Regards Ian.
02-03-2007, 11:11 PM
Post: #157
I'm getting excited just thinking about you thinking about driving it. Big Grin Thumbs up! Hurray!
02-03-2007, 11:46 PM
Post: #158
This is quite exciting project! I am wondering how would be ride in it, even in passenger seat .. Blush With this engine it must be breathtaking.
Good luck and keep on going! Thumbs up!
02-04-2007, 03:31 PM
Post: #159
Wow. Smile
But raised drivers floor? How much higher will it be then? Dumb question
02-04-2007, 05:06 PM
Post: #160
about 1cm or less - just has heel stops and lifts my feet up away from the heat that the exhaust manifold will generate (the primaries are long and the collector is right where your feet are Huh I here it gets a bit warm.
Regards Ian.
  Track AE86 Build from south america Nurburgring 3 8,188 10-30-2013 07:31 PM
Last Post: BOOMEX
  Ae86 Levin drift project. filip.alin 7 9,862 01-20-2013 03:05 PM
Last Post: filip.alin
  86er's Track rebuild N2.??? Finally an update page 8 86er 191 261,489 03-25-2012 10:05 AM
Last Post: bozu
  (AUS) 8age trueno track monster! green_boy_91 48 57,830 02-22-2010 01:47 PM
Last Post: green_boy_91
  KP61: The track fridge 127 Boy 20 30,862 01-04-2010 01:02 AM
Last Post: The Doctor
