Idle not going smooth...
06-10-2011, 08:31 AM
If the level of brake fluid is low, the handbrake light will also light up!
http://monkeymagic86.wordpress.com
06-13-2011, 10:40 PM
Ok, so I changed the plugs, I noticed plug No. 1 is sooooo black, put in new ones unplugging the wires one by one, when removing wire No. 1 there is no change, cranking is the same, and the temperature jumps to third after 5 minutes, alternator is working fine.
so what is it? failed injector, plug wire?
and the brake light is still ON Confused
  No idle below 2000 rpm rich running Steller Engineering 3 1,723 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 8,170 11-20-2021 04:12 AM
Last Post: GenkiMotors
  exhaust odor/idle MOT issue Ryo 7 7,796 07-15-2019 09:17 AM
Last Post: jondee86
  20v silvertop idle issue AlexFourTwenty 3 5,401 12-24-2017 03:27 AM
Last Post: AlexFourTwenty
  Silver top low idle AlexFourTwenty 7 10,646 10-16-2017 10:22 PM
