Idle problems
02-28-2009, 01:10 PM
If you don't bleed the cooling system well, you get an airlock at the back of the head. Sitting back there is the ECU coolant temp sensor. If you have an airlock you will get the idle situation you describe. It has happened to me and my highly experienced Toyota mechanic mate tells me it is common. Bleeding can be very fiddly.
Might be obvious, but check also you plug the loom plug back onto the sensor. Can't remember offhand if it is the green or brown one. |
Messages In This Thread |
Idle problems - filh - 02-21-2009, 10:57 PM
[] - The Doctor - 02-22-2009, 04:01 PM
[] - Sanity Clause - 02-22-2009, 07:55 PM
[] - Sanity Clause - 02-26-2009, 06:41 PM
[] - parrot - 02-28-2009 01:10 PM
[] - Sanity Clause - 02-28-2009, 02:26 PM
Suddenly, it all makes sense :) - jondee86 - 03-05-2009, 10:02 AM
Bouncing Idle - shawnho - 03-30-2009, 07:45 AM
Re: Bouncing Idle - jondee86 - 03-30-2009, 08:43 AM
Bouncing Idle Fixed - shawnho - 04-01-2009, 04:03 AM
Ghost in the machine :) - jondee86 - 09-17-2010, 12:03 AM
[] - irishtwincam - 01-13-2011, 12:49 PM
No idle below 2000 rpm rich running | Steller Engineering | 3 | 1,610 |
Engine starts/revs but no idle | GenkiMotors | 17 | 7,826 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
Big wheel problems | gh0st | 16 | 8,663 |
Starting problems 4-AGE kouki | Hanzo | 3 | 2,789 |
exhaust odor/idle MOT issue | Ryo | 7 | 7,617 |
