Idle problems
03-01-2009, 03:21 AM
If your sensors and all other peripherals were working before you changed the engine, they will still be working now, as long as everything is plugged in which it sounds likely to be.
The only thing changed by the sounds of it is the cooling system obviously. Do you still have a heater connected? Was it open to heat when you bled it? Keep trying, make sure you squeeze all the hoses once the thermostat opens so there are no bubbles etc.
If nothing else was changed between engines, I cant see what else it would be. The cycling idle, up to 2500 rpm and back to normal and over and over is exactly what you see with coolant sensor problems.
Good luck.
Messages In This Thread
Idle problems - filh - 02-21-2009, 10:57 PM
[] - tolisspi - 02-21-2009, 11:44 PM
[] - filh - 02-22-2009, 01:00 AM
[] - gtsr54321 - 02-22-2009, 06:44 AM
[] - jondee86 - 02-22-2009, 10:30 AM
[] - Ivan141 - 02-22-2009, 11:53 AM
[] - filh - 02-22-2009, 03:38 PM
[] - The Doctor - 02-22-2009, 04:01 PM
[] - Sanity Clause - 02-22-2009, 07:55 PM
[] - filh - 02-23-2009, 01:00 AM
[] - filh - 02-25-2009, 12:36 AM
[] - Sanity Clause - 02-26-2009, 06:41 PM
[] - filh - 02-28-2009, 01:01 AM
[] - jondee86 - 02-28-2009, 10:14 AM
[] - parrot - 02-28-2009, 01:10 PM
[] - Sanity Clause - 02-28-2009, 02:26 PM
[] - filh - 03-01-2009, 02:24 AM
[] - parrot - 03-01-2009 03:21 AM
[] - jondee86 - 03-01-2009, 04:16 AM
[] - JonnyAE86 - 03-01-2009, 05:21 AM
[] - filh - 03-01-2009, 07:57 PM
[] - jondee86 - 03-02-2009, 01:39 AM
[] - filh - 03-05-2009, 01:26 AM
Suddenly, it all makes sense :) - jondee86 - 03-05-2009, 10:02 AM
[] - Snejk - 03-06-2009, 06:34 PM
[] - filh - 03-11-2009, 01:54 AM
[] - alimonos - 03-11-2009, 10:20 AM
[] - filh - 03-12-2009, 01:14 AM
Bouncing Idle - shawnho - 03-30-2009, 07:45 AM
Re: Bouncing Idle - jondee86 - 03-30-2009, 08:43 AM
[] - filh - 03-30-2009, 01:43 PM
Bouncing Idle Fixed - shawnho - 04-01-2009, 04:03 AM
[] - filh - 09-16-2010, 10:44 PM
Ghost in the machine :) - jondee86 - 09-17-2010, 12:03 AM
[] - filh - 09-21-2010, 10:57 PM
[] - max_ae86 - 12-23-2010, 10:18 AM
[] - max_ae86 - 12-24-2010, 09:33 AM
[] - max_ae86 - 12-25-2010, 08:05 PM
[] - max_ae86 - 12-26-2010, 05:16 PM
[] - Hachi - 12-26-2010, 05:27 PM
[] - Ivan141 - 12-26-2010, 06:15 PM
[] - Hachi - 12-26-2010, 07:59 PM
[] - jondee86 - 12-26-2010, 10:16 PM
[] - max_ae86 - 12-26-2010, 11:11 PM
[] - max_ae86 - 12-26-2010, 11:34 PM
[] - Hachi - 12-27-2010, 02:34 AM
[] - max_ae86 - 12-27-2010, 10:03 AM
[] - max_ae86 - 12-27-2010, 10:58 AM
[] - irishtwincam - 01-13-2011, 12:49 PM
[] - max_ae86 - 01-13-2011, 01:23 PM
[] - max_ae86 - 01-13-2011, 01:34 PM
  No idle below 2000 rpm rich running Steller Engineering 3 1,414 11-30-2022 02:45 PM
Last Post: RolanTHUNDER
  Engine starts/revs but no idle GenkiMotors 17 7,126 11-20-2021 04:12 AM
Last Post: GenkiMotors
  Big wheel problems gh0st 16 8,013 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 2,597 08-31-2021 06:20 PM
Last Post: totta Crolla
  exhaust odor/idle MOT issue Ryo 7 7,228 07-15-2019 09:17 AM
Last Post: jondee86
