Igntition timing
06-24-2005, 11:55 PM
Igntition timing
Thanks all the advices.
My cylinder head has been renewed only a month ago. The ignition, the timing (crankshafts) have been set to their right positions and values. There was a trackday on a rallycross track (not so hardcore, believe me), where she suddenly lost power. My exhaust was leaky and it got one more leak at the "Y". I thought that the powerloss and this new leak are in connection with each other but now it seems they weren't (since I have a new exhaust). I thought that the distributor "felt down" to the bottom position (means: got retard timing) when hitting a bump, but that has not happened. My ignition timing is OK now. I think it's more a fuel problem somewhere....but dunno... |
06-25-2005, 11:43 AM
Igntition timing
Have you rechecked them though ?
I once had a similar problem, no real power and it took ages for the engine to build revs. After swapping engines i found the problem was in fact the bottom timing toothed pully. It had started moving on its key and was allowing it to rotate, effecting the timing. |
06-25-2005, 03:20 PM
Igntition timing
Hmm, JonT, not a bad idea. Next week one of my friends will help me find the reason of the problem, he is much more "talented" than I am. I'll tell him this idea.
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,556 |
4agze timing | leon205gti | 11 | 13,676 |
04-07-2017 03:10 AM Last Post: jondee86 |
Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 4,297 |
[Tutorial Video] Setting 4A-GE Ignition Timing | Homem Bomba | 0 | 5,490 |
04-21-2014 02:41 PM Last Post: Homem Bomba |
Broken 20v upper timing belt cover | chip | 2 | 4,213 |
07-16-2012 07:11 AM Last Post: Jan Pedersen |
