Igntition timing
06-24-2005, 11:55 PM
Igntition timing
Thanks all the advices.
My cylinder head has been renewed only a month ago. The ignition, the timing (crankshafts) have been set to their right positions and values.
There was a trackday on a rallycross track (not so hardcore, believe me), where she suddenly lost power. My exhaust was leaky and it got one more leak at the "Y". I thought that the powerloss and this new leak are in connection with each other but now it seems they weren't (since I have a new exhaust).
I thought that the distributor "felt down" to the bottom position (means: got retard timing) when hitting a bump, but that has not happened. My ignition timing is OK now. I think it's more a fuel problem somewhere....but dunno...
06-25-2005, 11:43 AM
Igntition timing
Have you rechecked them though ?
I once had a similar problem, no real power and it took ages for the engine to build revs. After swapping engines i found the problem was in fact the bottom timing toothed pully. It had started moving on its key and was allowing it to rotate, effecting the timing.
[Image: AEU86 AE86 - Igntition timing]
06-25-2005, 03:20 PM
Igntition timing
Hmm, JonT, not a bad idea. Next week one of my friends will help me find the reason of the problem, he is much more "talented" than I am. I'll tell him this idea.
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 13,550 07-18-2019 03:52 PM
  4agze timing leon205gti 11 13,669 04-07-2017 03:10 AM
Last Post: jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,295 11-05-2016 01:34 AM
  [Tutorial Video] Setting 4A-GE Ignition Timing Homem Bomba 0 5,483 04-21-2014 02:41 PM
Last Post: Homem Bomba
  Broken 20v upper timing belt cover chip 2 4,213 07-16-2012 07:11 AM
Last Post: Jan Pedersen
