Impreza Group-N project.
08-18-2008, 11:41 PM
Post: #141
Started working on the brake lines
I had to get some stuff before I could start, so I went to the scrapyard and took nipples I needed, from the newest cars they had, coz then they are still shiny. I also took 2 T-pieces which cost almost 40 euro a pop at the shop. Nipples: T-pieces: Looks like donkey balls, so I polished them a bit. As new!!: Everything together, in the shop almost a 100 euro's, at the scrapyard 10 euro. : I found the measurements of the AP-Racing brake fluid reservoirs I am going to buy, so I turned a dummy from plastic: Friend of mine had a "bead" machine which I borrowed, but before using it the line had to be cut off: This is how it works: For assisting me with the shape I found a piece of solid core wire. Then the real work started: This was ok, but I wasn't really satisfied. So today I redid the whole thing, and now I iz happeee: Now the rest. |
08-19-2008, 12:02 AM
Post: #142
looks n1. good going on the dummy
08-19-2008, 10:02 PM
Post: #143
08-21-2008, 07:43 AM
Post: #144
wow....went thru the entire thread. i commend you on some awesome fab work
08-21-2008, 08:52 AM
Post: #145
Thank!
08-21-2008, 07:47 PM
Post: #146
Im Imprezzed!
08-21-2008, 11:35 PM
Post: #147
you'r crazy, i loving it
08-27-2008, 07:19 PM
Post: #148
Yeah, for some reason the "beeing crazy" comment seems very populair these days.
But my shrinks say it's not true and I'm perfectly normal. |
09-14-2008, 10:40 PM
Post: #149
Small update,
Did another small piece of brakeline, the part to the left front wheel: AP-racing fluid reservoirs have arrived, my dummy worked pretty good I must say!: An air exit for the bonnet, WRC replica. This is something else that crossed my path, a new cable for the battery. It's aluminum with a silver coating, used in proffesional racing apparently. A bit bizarre, it's fingersize but weigh's nearly nothing: |
10-10-2008, 06:55 PM
Post: #150
FMIC time!
This job was sidelined for a bit but today I got some inspiration again. The endtank attachments had to be worked. There was a difference in width between the cores, so after contemplating a bit it was decided to change them altogether and make them as small as possible. So a tool was made and used: The IC needed to be heated up so the material would get softer and more workable. Fire up the ovens: Unfortunatly it cooled down rather quick, so I used a torch later. Mutilated a plier: First flattening occured : After that my new tool came into action: Viola, the result and difference: Next week I'll rework the radiator the same way. Now the 2 cores have to be welded together which is pretty risky, if that fails all this work has been done for nothing! Received some parts today, alloy tube and connectors: Next week more parts should follow, so more updates then. |
1984 Celica turbo b-group restoration | Roger | 8 | 10,108 |
04-24-2010 05:09 PM Last Post: corolla4agze |
