Impreza Group-N project.
12-25-2007, 01:33 PM
Post: #51
looking good
![]() A friend of mine as got a GL1.6l. A funny car indeed. ![]() Good luck with the rest. SR Team BURN THE RUBER NOT YOUR SOUL! |
12-25-2007, 02:49 PM
Post: #52
I just got to love scoobys.
![]() CumpĀ“s Filipe Oliveira |
12-25-2007, 03:48 PM
Post: #53
Looking good.
I like the newage dashboard much more. So just a little more to go ![]() Speed Industries Hurdnerwaeldlistr. 73 8808 Pfaeffikon Switzerland e-mail: [email protected] phone: +4155 420 15 69 page: http://www.speed-industries.ch MSN: [email protected] We have all the parts your Hachi needs |
12-27-2007, 09:14 PM
Post: #54
Done a bit today.
Monday we already fixed the dashboard console for the looks. Today we fixed it up. ![]() ![]() ![]() After that it was the heaters turn. I have to measure the whole thing out, so it fits perfectly to the tubes inside the top of the dashboard. ![]() ![]() Back together solid as a rock: ![]() Then it was time to rearrange the firewall, I have to cut holes for the airco, heater and engine loom. Halfway the hole the saw went dull, so I have to pick up new ones tommorow: ![]() |
12-27-2007, 11:17 PM
Post: #55
nice project,lots of work
![]() but wasent this a ''hachiroku''forum? i think i gonna make a topic of my hyundai pony project very soon ![]() ![]() ![]() sr86 completed!!........漂うことのマスター!!!! |
12-28-2007, 12:35 AM
Post: #56
u shoud upholster your dashboard like wrc car ... wirh rhar brushed leather stuff..
12-28-2007, 12:38 AM
Post: #57
Yeah, get it flocked!
12-28-2007, 10:57 PM
Post: #58
I will get it upholstered or flocked.
12-29-2007, 12:21 AM
Post: #59
Got me some new saws today, much better.
![]() I have to cut a few holes in the firewall, one for the airco, one for the heater itself and 2 more for engine looms. The new-age models have different connection terminals for the airco and heater so I have to adjust everything. I knew this was going to come because I had the same problems with the build-up of my other project, that's why I started with the dash on this project, good to have it out of my way. ![]() It might look simple to cut a few holes in the firewall and it is, but there are other problems. There have been made all kinds of foldings (not sure if this is the correct word for it) pressed into the metal of the firewall, this is for strength and against resonation. The airco terminal has to be tight to the firewall to prevent leakages so I have to make it flat. But when they press the folds into the metal it stretches it a litlle also, so when you try hammer it flat there is some material left, which has to go somewhere. So when you hit the firewall in one place it bounces back somewhere else. ![]() To cure this I have made cuts into all the stressed places, this relaxes the metal. So I had made a nice fitting hole: ![]() I had already fixed the heaterunit, into which the airco unit is built, so the position of the connection terminal was final, I had to make the firewall fit around it. The firewall had to be repositioned back and forth a bit to get it to fit the connection terminal, but due to the stresses the hole I first cut didn't come out right. So I had to make it bigger: ![]() I increased the hole a bit more because I decided that the coverplate was going to be bigger and incorperate one of the engineloom holes too: ![]() I used some packing foil as blueprint: ![]() Which I used for cutting it out in cardboard: ![]() Et viola: ![]() After that I started cutting holes for the heater connections: ![]() Then the day was over. ![]() |
12-29-2007, 02:11 PM
Post: #60
keep up the good work man
![]() "life begins at 8000rpms" - Going Racing ![]() |
1984 Celica turbo b-group restoration | Roger | 8 | 10,331 |
04-24-2010 05:09 PM Last Post: corolla4agze |
