Improve 20V Blacktop cooling
06-07-2023, 01:18 PM (This post was last modified: 06-07-2023 04:50 PM by pack.)
Hi all,
As you all know I'm running a 20V Blacktop since 2015. What an engine, bla bla bla! You all know that the 20V is a beast engine on this chassis.
As a matter of fact, I was able to purchase a second one, and I'm rebuilding that engine properly with all bits and bytes new or as much new as I can get.
Now, to the topic that made me open the thread.
I have my Dash sensor on the back of the engine, using the 16V factory outlet that has the two original sensors, with the ECU water temp sensor and the Dash temp sensor.
And I have a DEFI water temp sensor on that side plate right next to the headers to capture that area specifically and understand the temps at the back of the engine.
Behavior is, when I'm cruising slowly the temperatures reach a value that makes me uncomfortable, 102C.
When I accelerate they rapidly drop to 82C usually around that....
On the dash, im always mid temp as supposed, and with acceleration even the dash lowers the temperature a lot... i feel like the Mishimoto is working as it should here Smile
The other day I think it was John Russakoff on Facebook that something can be drilled on the back of the 20V head to allow that hot water pocket to communicate with the rear outlet and let the cooling flow better.
Does anyone have any info on what we can do to improve cooling?
Cheers
  Refreshed 20v blacktop first start.. Mylesmck 6 1,666 10-07-2024 07:55 AM
  20v Blacktop conversion.... Mylesmck 0 834 04-29-2024 05:48 PM
Last Post: Mylesmck
  Shims 20V Blacktop CHOPKIN2 3 5,428 12-23-2017 11:07 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 6,454 02-20-2016 11:48 AM
  Comp. Test - 20v Blacktop hachirokkos 2 5,314 01-10-2016 02:30 AM
Last Post: hachirokkos
