Info: 4age hi comp & Solex 40mm
09-30-2007, 11:32 PM
I'm plaining 2 buy solex 40mm side drafts and to put on red top small port hi comp, what else modification should i done fot this
1. adapter plate then....
10-01-2007, 05:52 PM
You'll probably need to change your fuel system a bit, I doubt the high-pressure EFI fuel supply would agree with those carbs.
If you keep the ECU for ignition you dont need much more.. FABRICA MI DIEM, PVNC! |
10-01-2007, 07:01 PM
I read on toyota nation that I need lower fuel presure valve than stock and lower fuel pump... but nower sad about specification of pump and FPR
10-02-2007, 01:05 AM
I think if you loop the original lines, and just feed the carbs of a T-piece everything will be ok..
Then again..I wouldn't like to try solexes after all the horror stories I heard..What about gutting them and just using them as ITBs? With stock ECU, piggyback etc A wheel to steer the front of the car A pedal to steer the rear |
| Toda timing info - with good general 4AG timing info too | oldeskewltoy | 0 | 7,394 |
| Comp. Test - 20v Blacktop | hachirokkos | 2 | 6,759 |
01-10-2016 02:30 AM Last Post: hachirokkos |
| Injector sizes info | ZaX | 19 | 44,432 |
07-17-2013 01:54 AM Last Post: jondee86 |
| frame/chassis rails info | Tig | 14 | 27,653 |
12-22-2012 10:38 PM Last Post: Tig |
| Collecting info for w58 conversion | ditn | 1 | 6,268 |
06-01-2012 08:59 PM Last Post: ditn |
