Info: 4age hi comp & Solex 40mm
09-30-2007, 11:32 PM
I'm plaining 2 buy solex 40mm side drafts and to put on red top small port hi comp, what else modification should i done fot this
1. adapter plate
then....
[Image: AEU86 AE86 - Info: 4age hi comp & Solex 40mm]
10-01-2007, 05:52 PM
You'll probably need to change your fuel system a bit, I doubt the high-pressure EFI fuel supply would agree with those carbs.
If you keep the ECU for ignition you dont need much more..
10-01-2007, 07:01 PM
I read on toyota nation that I need lower fuel presure valve than stock and lower fuel pump... but nower sad about specification of pump and FPR
10-02-2007, 01:05 AM
I think if you loop the original lines, and just feed the carbs of a T-piece everything will be ok..
Then again..I wouldn't like to try solexes after all the horror stories I heard..What about gutting them and just using them as ITBs? With stock ECU, piggyback etc
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,367 11-05-2016 01:34 AM
  Comp. Test - 20v Blacktop hachirokkos 2 4,946 01-10-2016 02:30 AM
Last Post: hachirokkos
  Injector sizes info ZaX 19 36,784 07-17-2013 01:54 AM
Last Post: jondee86
  frame/chassis rails info Tig 14 21,943 12-22-2012 10:38 PM
Last Post: Tig
  Collecting info for w58 conversion ditn 1 4,963 06-01-2012 08:59 PM
Last Post: ditn
