Injector sizes info
08-31-2008, 10:54 AM
Injector sizes info
tolisspi Wrote:So which bigger injectors can we connect on the bigport wiring injector? I want to fit bigger injector without mods.
what do you mean?
You can try the ones from the 3sge (2,0 engine, celica), the same ones are on the 7mge Supra (mk3)... I hear they put them on the 7AGZE engines, 1,8 SC
SNO-MO-BIRU project started- CHIRO
08-31-2008, 02:44 PM
Injector sizes info
Im meaning that i want to find injector to connect with the oem plugs wiring. Also the the bigport's injectors are 1ohm
**COROLLA EE80 - 4AGE 124HP**
[Image: AEU86 AE86 - Injector sizes info]
08-31-2008, 03:21 PM
Injector sizes info
robokill Wrote:MAKE IT A STICKY PLZ!
Sticky or in the technical section on the front page?
09-02-2008, 12:14 PM
Injector sizes info
in the technical section Hurray!
07-15-2013, 12:54 PM
Injector sizes info
Sorry for bumpy
This injector isn't in the list, what injector type is (burgundy)? Dumb question is from a '86 kouki european non catalized
What cc/min, ohms, lbs/hr and kpa are?
07-15-2013, 11:20 PM
Injector sizes info
What is the number on the side of the injector ?
Could be these...
Or these...
When you have the number, go here...
http://www.witchhunter.com/injectordata1.php
...and get the data.
Cheers... jondee86
07-16-2013, 04:06 PM
Injector sizes info
Thanks, great page...but is not in the list
Part number is 23250-16090 Dumb question
07-16-2013, 05:49 PM
Injector sizes info
Can't find any reference like that... Undecided
But they are 2.5 Ohm ones.... 365cc?! maybe can't confirm...
07-16-2013, 09:16 PM
Injector sizes info
I think 365 is too much, I imagine that will be 190-200 approximately, these were OEM in spanish (Cananrian Islands) kouki engines
07-17-2013, 01:54 AM
Injector sizes info
This guy has a picture, and they look like yours...
http://www.ebay.com/itm/TOYOTA-MR2-AW11-...2a2e396dc9
But it seems the Toyota part numbers can be a bit different....
23250/23209-16010/INJECTOR ASSY, FUEL (01.1984-11.1986) 4AGE..AE86
23250/23209-16090/INJECTOR ASSY, FUEL (11.1986-07.1987) 4AGE..AE86
23250/23250-16010/INJECTOR ASSY, FUEL (08.1983-01.1984) 4AGE..AE86
I'm not sure if the WitchHunter listing has been updated. The 23250
seems to be the Toyota Injector Assembly number, and the 23209-160XX
is the actual bare injector number.
Cheers... jondee86
  Toda timing info - with good general 4AG timing info too oldeskewltoy 0 4,367 11-05-2016 01:34 AM
  Injector voltage problem [fixed] d3nso 16 18,994 04-03-2016 12:39 PM
Last Post: d3nso
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 5,997 02-20-2016 11:48 AM
  frame/chassis rails info Tig 14 21,943 12-22-2012 10:38 PM
Last Post: Tig
  pink injector resistance Apsogos 2 4,144 10-01-2012 09:00 AM
