Injector voltage problem [fixed]
03-25-2016, 03:00 PM
Does it make a difference which injector you unplug? I doubt all 4 of them are bad. I'd still bet on a dodgy ground, due to the fact that the only injector firing will be the cold start one on the plenum. Hence just enough fuel for a few seconds.
AE86 ex-daily |
03-25-2016, 05:48 PM
No it doesn't make any difference which one is unplugged.
03-25-2016, 08:51 PM
Was this a running car or project build before the head removal? Considering the things you checked I'm still aiming towards the wireing, assuming it was a running car and none of the parts that matter have been changed
AE86 ex-daily |
03-25-2016, 09:13 PM
(This post was last modified: 03-25-2016 09:14 PM by d3nso.)
The car sat for 15 years until he bought it last summer. After the purchase he drove the car for 50-100km and endet up having his hg fail. The car is bone stock with arround 90.000km on it.
We also think it could be a Problem with the wiring loom. Daily Beater: Civic EG5 Work in progress Car: AE86 |
04-01-2016, 11:54 PM
Maybe you've checked this already but on my car, the power supply to the injectors come over two separate wires. One through to the ECU area and another through the connector between the engine looms behind the head. Maybe have a look there to make sure you have power from both sources?
04-02-2016, 07:01 AM
Q1. When the head gasket was replaced, was the fuel supply
hose disconnected from the fuel rail ? Q2. Does the fuel rail have a pulsation damper (metal mushroom) on top of the fuel hose banjo connection to the rail ? Q3. Have you tried disconnecting the fuel return hose from the tail of the FPR and then run the pump (bit of hose into a bottle) to check that there is decent flow as well as pressure in the rail ? Cheers... jondee86 |
04-03-2016, 12:39 PM
(This post was last modified: 04-03-2016 03:06 PM by d3nso.)
So the problem was found it was indeed the wiring loom. Some wires where broken just before the loom enteres the cabin. Thanks everybody for helping us out
![]() Daily Beater: Civic EG5 Work in progress Car: AE86 |
stock injector deadtime for 4age 20v silvertop/blacktop injector | ditn | 1 | 6,109 |
02-20-2016 11:48 AM Last Post: Bean |
removing light switch ? (fixed) | MC_JP | 10 | 17,484 |
09-18-2014 05:16 PM Last Post: MC_JP |
Injector sizes info | ZaX | 19 | 37,239 |
07-17-2013 01:54 AM Last Post: jondee86 |
pink injector resistance | Apsogos | 2 | 4,209 |
10-01-2012 09:00 AM Last Post: Ivan141 |
4agZe problem solved - 99% IC problem | Okami | 41 | 37,754 |
07-12-2012 04:49 PM Last Post: Okami |
User(s) browsing this thread:
