Is it worth it??? Please Read
02-14-2008, 07:33 PM
Hey!!
I can only say that I would definately go for it! And if what you say about the rust part is true. Then I would buy it any day! The 4AGE swap isn't that hard, just get a complete one with harness and all. Then it's out with the bad and in with the new. That car is a pearl, wish mine was is that shape :wink: But for now I have to work hard, just to get it on the road. Good luck with the purchase Regards Lars Veiss, Denmark Currently [URL=http://www.aeu86.org/viewtopic/dk-ae86-renovation-and-turbo-project---now-driveable/t/2474/start=150[/URL] |
02-14-2008, 09:24 PM
i got the wifey approval now which is good but now all i need to know is how to put the 4age motor in there and which 4age do i get? i saw a complete swap for $700 is that about right or was i looking at the wrong motor?
02-15-2008, 01:03 AM
I would say yes to this. If I could go out an buy an AE86 for $250 (£150 approx) I would go tomorrow and make it my project car, even if it is an SR5. With very little money you could get that car running with a brand new engine. You can even find a 20V silvertop in the states for $300, and on a body like that it wouldn't matter of you bashed in the firewall to get it to fit. Everything else after that would be small bits over time to get it running to specification.
For me, it would no doubt be a yes. |
02-15-2008, 02:07 AM
Jezza_hr Wrote:For me, it would no doubt be a yes. +1 Definately. You wont regret it. |
02-15-2008, 08:54 AM
ok what year of motors fit in this car? and what engine codes?
02-15-2008, 10:05 AM
ok i read the AE86 SR-5 to GT-S swap and have questions.... do i really need all the harnesses or just the engine harness? also how much i'm i looking at in order to put a 4age in this car?
02-15-2008, 05:11 PM
02-15-2008, 07:44 PM
You would need the complete harness (there is no other than engine/ecu harness), ECU and engine. dont know how things are in the US, but here in Europe, an engine with all the harness and ecu would range from 300-600 eur (500-1000 $), depending on the condition of the engine.
If the car really has that little rust, the chassis alone is worth much more. If you have the place to work on your car, than go for it. The swap itself is pretty straightforward, and the rest of the car is more or less basic in design, so its a pleasure to work on. |
02-15-2008, 10:53 PM
Boosted Wrote:You weld the diff to make it a closed diff... That way the diff can't distribute its power to only one wheel. Elcheapo solution for making a car drift, only drawback is that the handling of the car in normal road situations is degraded drastically.banpei Wrote:Just weld the diff and save 500 bucks. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
02-15-2008, 10:54 PM
meaning you need to drift to turn
Effects of valve lift - worth it going higher? | harkes | 18 | 16,769 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
Is used TRD exhaust header worth ~200e ? | Uzelac | 10 | 19,067 |
04-22-2011 10:40 PM Last Post: Uzelac |
Rotary AE86. Worth it? | someassemblyrequired | 5 | 10,088 |
05-13-2010 12:51 PM Last Post: someassemblyrequired |
Is it worth restoring an unused AE86 | gfxl | 16 | 16,083 |
03-22-2010 03:11 AM Last Post: sergiocharged |
mild cams... is it worth it? | megabob | 12 | 12,129 |
02-27-2010 08:12 PM Last Post: NonStopTuning |
