Is my 86 special?!?
03-23-2007, 07:06 AM
Is my 86 special?!?
If it is a GT-S and those don't have brackets, then you don't have one as well, you're just imagining things, Jan!
See, I can try to deliver sarcasme, but it just doesn't seem to be of high quality Sad
Seriously - if it's in the way, remove it Cool
03-23-2007, 09:36 AM
Is my 86 special?!?
http://samodisel.lorddigital.com/razni/A...G_1078.jpg
This is SR5 engine bay. The reservoir behind right front light is intended for front lights washer liquid.
03-23-2007, 09:49 AM
Is my 86 special?!?
I just looked this morning and I have the bracket as well. However as you can see here on P-Nuts car for the SR5 it is not used for the washer-liquid, but for the (bigger) radiator overflow. Dunno why, but perhaps the SR5 needed more cooling liquid. Tongue
[Image: AEU86 AE86 - Is my 86 special?!?]
03-23-2007, 11:41 AM
Is my 86 special?!?
is it just me or is that the tidiest engine bay i've seen in a while.... wish i could have mine look like that =|
03-23-2007, 01:01 PM
Is my 86 special?!?
Tidy? Well, if you look past the fuelcell, the batterycharger, the Gatorade bottle and the tools, i guess its kinda tidy...
03-23-2007, 08:38 PM
Is my 86 special?!?
I had another look to day, but it is impossible to get it to fit Confused It can be modified but I would rather have one that fits Smile
03-24-2007, 10:39 PM
Is my 86 special?!?
You cannot fit the standard 4AGE air filter box in there unless you grind off the circular mount for the radiator overflow/washer set up. That is all that bracket is for. So if you have a standard airbox then grind it off like I did, or put a pod filter in if that is legal (probably not - imagine it needs to be enclosed) Your body shell would have originally had a carby AC engine in it.
03-24-2007, 11:57 PM
Is my 86 special?!?
No it is originaly a 4AGE GT...
03-25-2007, 01:51 PM
Is my 86 special?!?
Well in that case, only thing I can think of is that it was fitted with an airflow meter intake at some stage as with the USDM versions? They have a different airbox and intake tube across the radiator than the JDM UKDM versions. Perhaps that airbox will fit onto that bracket. It is definitely the bottle mount as found in AC versions however.
03-25-2007, 09:46 PM
Is my 86 special?!?
I just remembered: One of the previos owners crashed the car and it got a new front end. Perhaps it wasn't the right one for a Euro-GT...
  Need special parts gh0st 4 2,817 09-11-2021 02:23 PM
Last Post: gh0st
  SPECIAL AE86 WHEELS GUIDE !!! eg6maxx 51 318,410 09-02-2012 12:31 PM
Last Post: Skyracer
  SST (Special service tools) questions. Ryo 4 7,635 04-06-2011 07:51 PM
Last Post: Ryo
  Toyota Special Service Tools (SST) S.K. 2 10,065 10-25-2009 05:13 AM
Last Post: yoda8
