It's worth checking your car
11-28-2007, 01:23 PM
I discovered this whilst trying to sort the bumpsteer problems on my car.
Basically you can't assume the centre of the steering rack is where you want to adjust your toe settings from, sounds stupid ?
I found that the inner balljoint on the steering rack did not align perfectly with the track control arm through bolt when the rack was at dead centre and I had all sorts of steering problems. All I did was move the rack until the inner balljoint pivot point was directly in line with the TCA bolt and adjust the toe setting from there, hey presto Hurray! Sorted all of the problems !
Watch out for this if you take your car to a shop to be aligned as they will generally centre the rack by counting the turns. Hope it all makes some sense. RS
11-28-2007, 02:35 PM
I'm about to install my QSR and I think I may need to do it as you say...
Best regards.
PS: That could be a nice Tech Topic if you could add some photos... but I guess that now that you've done the job you won't be taking any pics...
  Can you convert your 86 back too the original state? gh0st 7 2,983 04-25-2022 04:25 PM
Last Post: gh0st
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 21,090 08-19-2018 12:08 PM
Last Post: AlexKTM
  How would/have you rebuild your 4age? joaotcgt 6 8,970 07-21-2015 10:40 AM
  Your Attention, Please.... oldeskewltoy 1 3,769 07-30-2014 09:04 PM
Last Post: driftmaniacae86
  Checking ring gear diff izanagi 3 5,053 07-09-2014 07:38 AM
Last Post: jondee86
