Ive been busy.. F20C AE86 (56k badness!)
04-18-2008, 04:46 PM
Hi Paz,
That's cool. I'd be sick to death of mine too if I put as much work into it in tight confines in freezing weather as you've just done! Yeah, I realise the F20 swap's an issue of budget / power. There's nothing to say you won't get it all working OK after ironing out the inevitable challenges that come with a swap like this. If I'm not mistaken, from memory and from seeing my engine compared to standard ones, TRD mounts are slightly shorter than standard ones, so this might cause further problems with clearance and perhaps with dropping the F20 engine closer to the ground too? Maybe a solution for the chassis rail would be to strip the area where it's close and paint it with high temp red paint...? Or you could cut away a part of it, then re-build it slimmer, with strengthening inside (Or both!?) Or take off the exhaust manifold cut it and re-weld about 1.5cm closer to the engine block? I guess you just gotta try it and see if there's interference and if so where , then deal with come what may.. Once you're all done and it works good, make a kit so other mere mortals can copy it - or some detailed instructions. You'd maybe sell a few to recoup some of your costs that way? Keep us posted! VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
04-18-2008, 09:06 PM
always the business man Miguel
![]() Paz I bow down to your godly skillz ![]() DRIFTING is pushin a car against its intended design, then playing with the LAWS OF PHYSICS |
04-19-2008, 06:12 AM
The Big Yin Wrote:always the business man Miguel Only suggesting an idea - which might help more of you to get powerful AE86's without as much hassle! ![]() VISIT OUR NEW WEBSITES!!!! A Tuner's Paradise Automotive Art On Film Dedication To Automotive Perfection Japan Office Tel - (Calls charged at UK National Rate): 0207-193-3979. Mobile (Japan): +81- (0) 90-4133-3825 Fax (Japan): +81-(0) 47-307-4678 |
04-20-2008, 12:33 AM
Paz, looking good
![]() I'm currently taking HRT ~ Hachi Roku Therapy ![]() |
05-06-2008, 08:57 PM
Well it works! I had a serious oil burning issue but apparently its a common fix with the breather. It dumps oil into the intake manifold under breaking followed by a sharp right turn/accleration.. Modified the breather setup and the drain baffle under the cam cover to suit, hopefully this will fix my issue.. And aside from that, and killing my bumper, the car ran faultlessly it seems.
But yeah onto the business side of things! I got it mapped and made 215hp and 175ft/lbs of torque. Odd that torque is up and HP is down on the predicted levels... But im pretty sure its the manifold thats losing me 15-20hp. So i'll be making another with 100% equal length runners, as my current manifolds runners are far from equal length. But for now, its fast enough and has massive amounts of traction and grip, linear power is so good for fast drifting! Onto the pics.. ![]() ![]() ![]() ![]() So, i need to clean and finish the interior, hook a few more gauges up and re-paint it as im really not happy with the paint.. And get driving! Driftworks - JSPFab.com - DangerStyle - NightSpirit |
05-06-2008, 09:35 PM
who got your old engine?
05-07-2008, 01:17 PM
What a piece of art that is!
Great woth Pazwah! ![]() ![]() adam |
11-12-2008, 12:41 PM
Hi,excellent project,im doing the same at the minute,gor engine mounts from jsp fab,great fit,i was wondering where you got that exhaust header,lovely job........thanx
11-12-2008, 03:35 PM
great ride toyonda
11-12-2008, 04:57 PM
heard that Pazwah-san has already built his 2009 drift car!!
ae86 Trueno f20c Built to be driven not polished | Martynas | 45 | 57,015 |
05-29-2020 12:59 PM Last Post: decryphe |
OST-063: Busy Boy | oldeskewltoy | 4 | 4,822 |
12-24-2019 01:55 AM Last Post: oldeskewltoy |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 164,946 |
BT20V out F20C in !! | malejyetti | 54 | 72,724 |
06-17-2015 07:05 PM Last Post: banpei |
wiring digram for an f20c to ae86 | ae86 for sale | 0 | 4,896 |
05-21-2014 11:52 PM Last Post: ae86 for sale |
