Jdm ae92 smallport specs (4age)
02-19-2006, 05:54 PM
Hi guys
This is my first technichal post, i haved try the search mode, but i cannot find anything over the specs for this type of engine, i do know the specs from the Usdm models, but i thing that it has to be a little bit difference between those Does somebody know this??
02-19-2006, 07:19 PM
el_chico Wrote:Hi guys I don't think if is there any phisycal difference between the engine blocks/cylinder heads. The main difference is in the air measuring, the USDM has AFM based and the JDM has MAP sensored system. And the JDM has more agressive ignition map, and has no emission pack (EGR) Thats why the USDM has ~125hp anf the JDM has ~140hp. |
02-19-2006, 07:53 PM
Billzilla has some things on the differences between the blocks:
http://www.billzilla.org/4agstock.htm#summary And also this is a good page for comparing them: http://home.clear.net.nz/pages/phil.brad...%20RWD.htm But they don't say too much about differences between USDM and JDM (since they both are from down under )
02-20-2006, 06:24 PM
thanx guys
| Differential specs | MatuOjav | 2 | 323 |
12-03-2025 07:06 PM Last Post: MatuOjav |
| Smallport coil | totta Crolla | 2 | 2,883 |
08-12-2022 11:03 AM Last Post: totta Crolla |
| Smallport inlet manifold | totta Crolla | 6 | 4,965 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| AE86 Battery specs | hachirokuGTV | 9 | 19,963 |
03-13-2020 04:16 PM Last Post: Power_uP |
| 4A-GTE 7-rib smallport | nyberrg | 5 | 7,802 |
05-24-2017 09:24 PM Last Post: krullibull |
![AEU86 AE86 - Jdm ae92 smallport specs (4age) [Image: AEU86 AE86 - Jdm ae92 smallport specs (4age)]](https://www.aeu86.org/sticker-banner-468.gif)
