Knudsens project
07-04-2006, 01:03 AM
Knudsens project
Coming along nicely mate. It looks to be in fairly decent condition too.
07-04-2006, 01:08 AM
Knudsens project
Thanks! Yeah, its not bad atall - my luck Big Grin
BTW, i desperatly need some rearbumper extensions. Anyone have a spare set?
07-05-2006, 12:26 AM
Knudsens project
Last from the spoiler: I gave it a whiff of primer, then its easy to see where to sand or putty some more. I need to give it a sanding to make it perfect.
[Image: AEU86 AE86 - Knudsens project]
Then it was the OE antennahole that needed some attention.
First i welded a small piece of metalsheet on. I know my welds look a bit shitty, but its hard to weld without heatbending the fender to much:
The other side after sanding
Due to a small heatbend, i needed to give a larger area putty - this is after sanding ( i use fiberglasputty):
More putty, more sanding.
The final layer of polyester PP100. This is before sanding offcourse.
Stay Tuned for more updates! Thumbs up!
07-07-2006, 12:40 AM
Knudsens project
Got the rearwheel arches done today. They have only had one layer of filler, so they need alot more attention in form of filler and sanding (man, my arms are getting longer and longer)
I got the rusty area inside the right inner wheelcasing done, it now look like this:
And finally the hole in the top of the hatch is welded shut. That needs some filler too:
Dont hesitate to comment! Thumbs up!
07-07-2006, 07:42 AM
Knudsens project
Your doing some nice work so far.. I know how much work it is to get all that bodywork smoothed out again with filler, it can be quite a challenge sometimes. You still have a nasty little bump in the wheelarch in those pictures, but you mentioned your not done yet so that's not an issue I guess.
07-07-2006, 09:59 AM
Knudsens project
If the bump youre mention, is the one in the last wheel picture - it should, according the smith, be filler.. So it should be rather easy to sand down, but time will tell. I know theres some long evenings with filler and sandpaper yet to come. Sad
Im just happy that all the rustwork is complete, and the paintjob is much closer.
07-24-2006, 06:48 PM
Knudsens project
Made some progress today, the car goes to the paintshop later this week.
07-24-2006, 06:59 PM
Knudsens project
Nice Work! I can't wait seeing the final result Thumbs up!
07-24-2006, 08:49 PM
Knudsens project
Whow! someone has been busy!Big Grin
07-24-2006, 09:29 PM
Knudsens project
damm.. what color?? wnat more pics
