Kristian from Sweden
12-25-2004, 11:11 PM
Post: #161
- i got a question for the guys with KONI short-stroke´d front shoxs.
on the right side of the spring there is an rubber/plastic "cup" that is located between the coil (spring) & the Camberplate.
Will this "cup" act in the same way as this item from T3 ? Se last picture please.
or, should i get this item from T3 instead ?
regards /
..............Kristian
12-26-2004, 12:31 PM
Post: #162
I think getting the upper hat would be a good idea, it looks like the camber plate itself doesnt have enough surface and the correct shape to keep the coilover in place at the top. Also the upper hat has bearings in the midle ring on the picture, making adjustment of the coilover a lot easier..
12-26-2004, 05:22 PM
Post: #163
nice stuff Kristian hows everything comming along?
12-28-2004, 12:20 AM
Post: #164
4 kris
12-28-2004, 02:07 AM
Post: #165
That "upper hat" of yours looks quite inventive Zax, I reckon that would work pretty well as long as it stays in one piece. Dunno how much Gabe charges for the upper hat, but it cant be very much, so I dont see the point in using this approach unless your short on time or money.
12-28-2004, 11:16 AM
Post: #166
2 ivan: i'm allways short of money. I will order t3 upper hats (around 50$), but at the moment i don't have any other solution. Anoying part is the noise that this setup makes over the bumps.
More pics for kris on his request.
Sturts, shortened.
12-28-2004, 11:24 AM
Post: #167
So i figured out that i need wheel spacers.
I used 20mm momo spacers, also oredred long wheel studs from japan.
So with spacers, i could even use the +37 offset wheels without the rubbing.
And inside, i could lower the coilover nut without the rubbing on the tire!!!
12-28-2004, 11:28 AM
Post: #168
Mmmmm oposite lock...
Sexy low rider
Purfect!
12-28-2004, 12:49 PM
Post: #169
Nice car Kristian,
but what about the suspension?
it looks very soft man, car is bending too much in corners, no?
Anyway, I m really interested to know about the hood mod you 've done. This is a fiberglass hood right? I 'm interested in doing the same mod in hood mounts, but on the oem hood. Can you help me with some information or maybe some pics please?
[Image: AEU86 AE86 - Kristian from Sweden] http://www.jdmbits.com
12-28-2004, 01:59 PM
Post: #170
nmwisima Wrote:Anyway, I m really interested to know about the hood mod you 've done. This is a fiberglass hood right? I 'm interested in doing the same mod in hood mounts, but on the oem hood. Can you help me with some information or maybe some pics please?
It's the original hood remade by Kristian himself, i saw a lot of pictures during the build last winter, gonna see if i find them before Kristian repost them.
Best Regards,
Edit: Found his old thread, swedish forum. LOTS of posts and lost of images, dunno if they all still work.
http://forum.zatzy.com/showthread.php?s=...hlight=huv
  Hello from Sweden Skyracer 5 6,240 01-11-2012 07:25 PM
Last Post: Skyracer
  New guy in Sweden :) krullibull 21 20,348 05-30-2011 03:28 PM
Last Post: kennedy8383
  New member from Sweden! Bentley 12 12,821 04-30-2011 12:25 PM
  New Member. Sweden Stockholm Allexz 5 6,073 10-18-2007 05:25 PM
Last Post: S.K.
  Hello from Sweden! Hedlund 4 5,088 03-18-2007 09:26 PM
Last Post: S.K.
