***Ksport*** What about theese coilovers? Cheap?
01-19-2007, 05:12 PM
So i found this shop today (http://www.ultrarev.com) and they have some cheap ass coilover sets..
http://www.ultrarev.com/Ksport_Kontrol_P...31351.html
Ksport Kontrol Pro Damper Coilover System Toyota Corolla (AE86) 1983-1987 #CTY07-KP
[Image: AEU86 AE86 - ***Ksport*** What about the...rs? Cheap?]
Key Features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
Price: $858.00
?? 650 eur for 4 coilovers with camber adjusters? what am i missing here?
they also have 2 more expensive kits:
http://www.ultrarev.com/Ksport_Slide_Kon...31400.html
http://www.ultrarev.com/Ksport_Version_R...31909.html
@1000$ and 1200$, which is again not so expensive for a full coilover set..
so whats up whit theese? anyone tried them yet?
01-19-2007, 05:30 PM
A friend with Chrysler Neon purchased K-Sports. They were cheap, he was satisfied. The car is used only for amateur track race. Recently he damaged one strut (lost turn on the track) and the replacement insert came less than 2 months after purchase.
01-19-2007, 05:34 PM
Driftworks.com and Apexperformance.co.uk do deals with K-Sport: have a look there for reviews... AFAIK most are more than satisfied with theire products (think they are made by another big company that does some of the big brands too) Wink
01-19-2007, 06:08 PM
yeah, i thought so too. im just wondering what kind of shocks are used. tokico, kyb?
01-19-2007, 06:10 PM
I wonder what shipping would do for these things... They look pretty good.
Also wondering what they got for the rear and if they are also coilovers, if modifications are needed...
01-19-2007, 06:18 PM
i've read on driftwork.com, they can suply theese coilover sets for other brands too. where is driftworks' shop located? GB? coz that would put those coilovers closer to us, and real close to you mux Smile
btw, as you can see from the pic, the rear set is coilovers also. this really doesnt look that bad, and for the price they just might get on my to-buy list. net some positive feedback first..
01-19-2007, 06:33 PM
I have Ksport coilover in my car, works fine but are very stiff! standard spring rate is 7kg front and 5kg rear, but you can change it when you buy....
Now ksport just start to sold 2way coilovers... is a good option.
If you want ask here http://www.kdperformance.com/ is a Ksport dealer for Spain, 200% good seller. [email protected] .Ask for "Kike" and said that I tell you the email... Is my friend and I´m sure you will have the best attention...
you can see my pic in the signature? Grey CTR, SW20, Integra, and AE86... all with Ksport and all happy
Regards
01-19-2007, 06:38 PM
Apolan Wrote:btw, as you can see from the pic, the rear set is coilovers also..
ummmmm the real kit for ae86 is this...
[Image: AEU86 AE86 - ***Ksport*** What about the...rs? Cheap?] but whitout panhard.
Rear shock are threaded to intall coilover spring in the future if you want.... But when you buy the spring is standard not coilover.... because for put coilover need reinforcement the chasis.
Regards
01-19-2007, 08:32 PM
Abe, do you have pictures with it installed on your car?
From the looks of it some alterations to the front strut will be needed aswell?
Allready thought the earlier picture was setup from another carBig Grin
01-19-2007, 09:11 PM
Abe much tanks for your opinion on the shocks. I also thought those were CO-s for some other car couse of the shape of the attached bracket. Thought might still be 4 coilovers. Hey is that top mount camber adjustable or not? Coz it says on the page it might not be availible for some cars..
one sideline qustion, how much is the highest ride height with theese Coilovers, compared to stock? and how much lowering can they do. And if the rears ar not height adjustable, what good does it do to have fronts adjustable?
  Carina drivers! - Coilovers for a TA60/62 nyberrg 2 7,901 06-05-2017 10:03 AM
Last Post: nyberrg
  Fitting driftworks CS2 coilovers bozu 2 6,106 05-30-2017 10:50 AM
Last Post: bozu
  D2 Coilovers any good? heshan 18 31,920 04-04-2017 02:40 AM
Last Post: hachirokkos
  Has anyone tried BC Racing coilovers? AlexKTM 9 15,128 09-05-2016 12:28 PM
  Anyone running DIY Coilovers? Rasteirinho 8 16,118 11-19-2013 10:30 PM
Last Post: totta Crolla
