LHD W.G (West Germany) wires from dimmer & dash switch to headlight relays?
07-06-2014, 10:56 PM (This post was last modified: 07-06-2014 10:58 PM by Rascal21.)
The latest oscillation problem can be attributed to low voltage in the engine room battery cable.
I fixed this by recharging the battery and soldering all the battery cable related cable shoes.
I have working low beam, but high beam still only works with dimmer handle halfway pulled towards me (Before it clicks into position).
So I took a gutted spare switch and tried that, same problem.. No idea whats going on here..
1x AE86 84` Zenki Coupè Levin 4A-GE 20v
1x AE86 83' Zenki Coupe Levin 4A-GE 16v
1x TA60 82' Sedan 2T 8V
1x TA40 78` MK1 Zenk/Pre-Facelift Wagon 4A-GE 16v
07-07-2014, 09:16 AM
Try removing the headlight bulbs, then measure voltage at the power outputs to the bulbs in order to check your relay circuitry.
I get the feeling you are overthinking these electronics, there is very little in there that could cause any real oscillation. Mostly those kinds of effects can be attributed to low voltage on the relays, causing them to trip on and off fast.
Also , if you're unsure about the switch, connect Red-Yellow switch wire to ground with a temporary toggle switch so you're sure the dimmer relay is being controlled properly.
BTW, did you disconnect the indicator light circuit again? You say you had it working before you added that circuit, so it would be logical to undo that first to try to get back to a working system.
  Ignition switch plug and wires Blaze0010 3 297 11-25-2024 12:29 PM
Last Post: Blaze0010
  Digital Dash evfan42 190 261,212 05-03-2024 06:44 PM
  Fitting Air Con (No PS) to LHD AE86 pack 7 4,064 01-07-2024 11:36 AM
Last Post: CCB
  Dash Waning Lights pack 7 4,218 10-06-2021 01:00 PM
Last Post: pack
  TUV RHD AE86 Germany (help please) 4dori 9 6,842 07-17-2019 07:42 PM
Last Post: Hachigo83
