LSD question
07-17-2007, 01:28 AM
LSD question
idk if this question has been asked or whatever...
If I took the pumpkin off a GTS rear end and stuck it into my SR-5 rear end, will it fit?
07-17-2007, 04:18 AM
LSD question
Maybe, depending on what type of rear ends SR5's had.
The GTS has a T series rear end. Do SR5's have T or S series rears. LSD's are not available for S series diffs.
Have a look on your build plate and see what it says next to transaxle. T50 refers to the gearbox, the rear axle will be a code something like S314 or T282.
If you have a T series, yes you can bolt in the LSD, if you have a S series, no you can't as the ring gear diameter is too big - 6.7 inch vs 6.38 inch.
See here for more info on interpreting diff codes.
http://www.toymods.net/forums/showthread.php?t=350
07-17-2007, 06:07 AM
LSD question
alright thanks parrot ill check tommorow or so
07-17-2007, 05:22 PM
LSD question
parrot Wrote:Maybe, depending on what type of rear ends SR5's had.
It's a US model ae86. The sr-5's ONLY came with the smaller 6.38" rear end with drum brakes. They did not come with the 6.7" (t-series) diff's with drum or disc brakes.
So no, he can't swap a gt-s pumpkin into an sr-5.
Andrew
07-17-2007, 05:55 PM
LSD question
Same problem we have in Australia. We didn't get a GTS version here at all, and all Australian Sprinters were very basic SR5 type spec, or AE85 spec if you are from New Zealand. So we rely on importers to bring in t series rears from japan. $$$$
  OEM LSD Question heshan 26 30,902 07-19-2014 08:18 AM
Last Post: heshan
  Upgrading no-LSD diff to LSD one Snejk 22 27,495 04-01-2008 04:46 PM
Last Post: Snejk
  LSD question senna 3 5,332 09-25-2007 07:32 AM
Last Post: senna
  LSD question Hoey 16 20,601 03-13-2007 10:04 PM
Last Post: assassin10000
  LSD Question woper 12 14,466 01-26-2007 03:36 AM
Last Post: Abe
