Levin Coupe from Croatia - NOW SR86 with IRS
01-11-2005, 10:58 PM
Post: #91
hmmz nice work zax you really pull things off with standard equipment
01-11-2005, 11:07 PM
Post: #92
robokill Wrote:hmmz nice work zax you really pull things off with standard equipment This is called TUNING! Hope to finish soon with "restoration" part. Drifting - best fun you can have in your car with your pants on! |
01-14-2005, 11:57 AM
Post: #93
Mounted new water pump -> old one was leaking
Mounted new thermostat, just in case. New timing belt. Drifting - best fun you can have in your car with your pants on! |
01-14-2005, 10:06 PM
Post: #94
Little something i started working on this evening.
I'm not using these vents on my dashboard, so i decided to fill them with something more usefull. I like the "old" design of VDO gauges, they look similar to ae86 dashboard, also with green glowing light. Hope to finish electric part tommorow. Drifting - best fun you can have in your car with your pants on! |
01-16-2005, 06:48 PM
Post: #95
Senders not yet connected. Any idea where is the best place to install oil pressure and oil temp. senders? Drifting - best fun you can have in your car with your pants on! |
01-16-2005, 07:01 PM
Post: #96
Love that, zax! Looks great!
Now you got me wanting to have oil meters as well.. As if I didn't have enough work to do... |
01-16-2005, 07:19 PM
Post: #97
I definately want an oil temp meter
01-16-2005, 08:40 PM
Post: #98
You already have an oil presurre sender, I dont think it will work if you split the signal wire. If you have a new pressure sender you could take off the original one, place a t-piece on it and install the extra pressure sender on that.
Oil temps should always be measured in the oil pan. I installed my oiltemp sensor in the drain plug, but that is a slightly risky place to put it. Best solution is to weld an extra bit of metal to the pan, drill it and tap it for the correct thread. FABRICA MI DIEM, PVNC! |
01-16-2005, 09:37 PM
Post: #99
Hey Zax,
You have been busy !!!. how much trimming was required after you'd removed the spinning air vents ? I guess they are 52mm gauges yes ? Regards Ian. |
01-17-2005, 12:13 AM
Post: #100
Im about to install a oil-temp gauge myself. Im planning to mount the sender, in the outtake to the oil cooler, in a T-piece.
Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 15,122 |
@dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 161,337 |
Aram's 3SGE Beams Levin Coupe | robokill | 665 | 740,617 |
Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 40,326 |
04-07-2016 12:15 PM Last Post: mad.matt |
DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 5,469 |
08-13-2015 03:22 PM Last Post: DidiDex |
