Levin Coupe from Croatia - NOW SR86 with IRS
01-11-2005, 10:58 PM
Post: #91
hmmz nice work zax you really pull things off with standard equipment
01-11-2005, 11:07 PM
Post: #92
robokill Wrote:hmmz nice work zax you really pull things off with standard equipment
This is called TUNING! Hurray!
Hope to finish soon with "restoration" part.
01-14-2005, 11:57 AM
Post: #93
Mounted new water pump -> old one was leaking
Mounted new thermostat, just in case.
New timing belt.
01-14-2005, 10:06 PM
Post: #94
Little something i started working on this evening.
[Image: AEU86 AE86 - Levin Coupe from Croatia - ...6 with IRS]
I'm not using these vents on my dashboard, so i decided to fill them with something more usefull.
I like the "old" design of VDO gauges, they look similar to ae86 dashboard, also with green glowing light.
Hope to finish electric part tommorow.
01-16-2005, 06:48 PM
Post: #95
Senders not yet connected.
Any idea where is the best place to install oil pressure and oil temp. senders?
01-16-2005, 07:01 PM
Post: #96
Love that, zax! Looks great!
Now you got me wanting to have oil meters as well.. As if I didn't have enough work to do...
01-16-2005, 07:19 PM
Post: #97
I definately want an oil temp meterSmile
01-16-2005, 08:40 PM
Post: #98
You already have an oil presurre sender, I dont think it will work if you split the signal wire. If you have a new pressure sender you could take off the original one, place a t-piece on it and install the extra pressure sender on that.
Oil temps should always be measured in the oil pan. I installed my oiltemp sensor in the drain plug, but that is a slightly risky place to put it. Best solution is to weld an extra bit of metal to the pan, drill it and tap it for the correct thread.
01-16-2005, 09:37 PM
Post: #99
Hey Zax,
You have been busy !!!.
how much trimming was required after you'd removed the spinning air vents ? I guess they are 52mm gauges yes ?
Regards Ian.
01-17-2005, 12:13 AM
Post: #100
Im about to install a oil-temp gauge myself. Im planning to mount the sender, in the outtake to the oil cooler, in a T-piece.
  Trueno Hatch and Levin Coupe - Repair, replace, pray xD TomRich 13 14,742 10-07-2018 09:45 PM
  @dodo@ Levin Coupe, renovation and tuning (56k think twice) @dodo@ 165 158,941 03-28-2018 12:35 PM
  Aram's 3SGE Beams Levin Coupe robokill 665 727,536 09-03-2017 09:24 PM
  Matt's "Drives as fast as it's Towed" 85 Levin Coupe mad.matt 38 39,537 04-07-2016 12:15 PM
  DidiDex 1984 Levin coupe rebuild DidiDex 1 5,370 08-13-2015 03:22 PM
Last Post: DidiDex
User(s) browsing this thread: 18 Guest(s)
