Levin kouki - zenki sidelights ?
10-15-2008, 12:28 PM
Beside orange/black differences, are they the same ?
Are they interchangable, can be put on every AE86 Levin, regardless of model of sidelights ? I need to buy both headlights, and thinking of going to kouki front with glass grill. But, both of mine sidelights are in great condition so don't wanna buy other . Thanks. |
10-15-2008, 02:06 PM
no prob,
you can put zenki with blinker zenki without blinker kouki with blinker are all interchangeable Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
10-16-2008, 01:56 AM
Great, thanks.
Btw. glass grill is somewhat cheaper than plastic zenki ?! It doesn't make sense, but i certanly won't compalin |
10-16-2008, 10:16 AM
The mounting holes on the fenders are not the same for zenki & kouki though (easiliy fixed), and the lines will be "off" when mixing and matching zenki & kouki headlights and corners. This is because the kouki's have those little lids on the headlights, the corners have a thicker black line on top and bottom too because of this ( so the lines continue into the corner lights).
10-16-2008, 09:55 PM
I'm leaving zenki corners and sidelights, just wanna put kouki headlights and grill.
As much as you told me, there aren't going to be any problems. |
10-17-2008, 10:18 AM
No, there arent going to be any problems, it will just look a little odd at the corner lights. I've done the exact same thing to my own hachi, didnt want to fork out money for new kouki corners, and couldnt find used ones.
10-17-2008, 11:56 AM
Ivan141 Wrote:... it will just look a little odd at the corner lights. Why ? Just to be sure : My car is zenki. I have zenki sidelights (position/parking lights). Corner lights are not important, on my car they are far towards the door, My wings are genuine zenki. I want to buy kouki headlights and grill. Only fitment problem i can see that can happend is sidelights<->headlights and hood<->headlights/grill. |
10-17-2008, 03:03 PM
Mislim da me nisi dobro razumio..
It will fit just fine, no fitment problems as long as you keep in mind that you need to keep the grille and headlights of the same type since the grill mounts are different. But the sidelights will not match with the headlight trim. Personally I thought mine would look better with kouki sidelights. Have a look. FABRICA MI DIEM, PVNC! |
10-17-2008, 03:18 PM
Ne, definitvno se ne razumemo
Are you aiming at not so good fit between headlight and sidelights ? I don't see any other flaws . |
10-17-2008, 06:42 PM
Look at the differences in the tops of the corner lights.. the kouki ones have a much thicker black line there. The zenki corners have a thin line that does not even go all the way to the headlight. Maybe I'm a bit too fussy, but it's just a cosmetical detail. Anyway, enough about that, best of luck with the project.
Kouki to Zenki Levin grill conversion? | Mylesmck | 6 | 2,090 |
Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 7,781 |
Why Zenki and Kouki colour difference | MIGGZFSU | 10 | 18,877 |
04-23-2017 09:16 AM Last Post: MIGGZFSU |
brake booster difference zenki(2 bolt)/kouki 4 bolt v | ditn | 1 | 4,293 |
03-22-2016 09:43 PM Last Post: ditn |
zenki and kouki model rear axles | megabob | 7 | 8,781 |
03-13-2013 08:43 PM Last Post: megabob |
