Little starting Problem
06-03-2009, 12:19 PM
Hey!
My stock 4AGE Engine had a little starting problem when the engine is hot.
When it´s absolutly cold, i turn the ignition key and the engine runs perfectly, when the engine is hot, i turn it off and after a very short time i start it again it also starts great and runs perfect in idle BUT when the engine is warm it doesn´t start at all, i have to push the throttle just a little and after a time the motor runs....
i changed the sensor and the coldstart injector, but no change at all :-/
[Image: AEU86 AE86 - Little starting Problem]
thanks for your help
06-03-2009, 12:37 PM
Have you got all your temperature sensors (air and water) installed and
hooked up ?? Have you got an electrical idleup valve hooked up ?? Still
got winter fuel in the tank ?? Got a fresh set of plugs installed ?? Ignition
timing checked and set correctly ??
Cheers... jondee86
06-03-2009, 12:41 PM
all sensors are installed, got fresh shell gas in my tank :-D
Sparkplugs are 2000 km old....
electrical idluep valve hooked up? what do you exactly mean?
06-03-2009, 08:21 PM
I had a similar problem due to excessive ignition advance a long time ago.
Reinstalled my distributor a tooth off. It would start fine when cold, and very difficult if at all when warm.
06-04-2009, 07:50 AM
AshCampbell Wrote:Electrical idleup valve hooked up? what do you exactly mean?
Most, if not all 4AGE's have some form of electrically operated idleup
valve. Its purpose is to provide a small amount of extra air to help,
among other things, the engine to start. It usually allows filtered air
from the intake ducting into one of the small vacuum connectors on the
throttle body.
Some engines will also have a vacuum operated "throttle lifter" on the
side of the throttle body. This has a little spring-operated rod that pushes
the throttle slightly open when you turn the engine off. Once the engine
starts, engine vacuum acting on a diaphragm, retracts the rod so that it
does not interfere with normal idle.
Both of these devices are designed to save you having to crack the
throttle open when starting. But check you timing anyway Smile
Cheers... jondee86
  lntermittent starting totta Crolla 6 3,966 08-31-2021 06:21 PM
Last Post: totta Crolla
  Starting problems 4-AGE kouki Hanzo 3 2,870 08-31-2021 06:20 PM
  JDM trueno not starting. need help! kazi 8 9,262 03-12-2017 05:05 PM
Last Post: kazi
  20v Starting Issues mad.matt 10 12,270 09-24-2014 12:44 PM
Last Post: pack
  starting/electrical issues Jezza_hr 14 19,140 12-21-2013 05:45 PM
Last Post: Apsogos
User(s) browsing this thread:
