Lost Key
06-13-2009, 12:36 AM
Lost Key
My Trueno didn't come with a key when I bought it.
I called the Toyo dealer they said there was a key code on one of my door locks cylinder. I got the code of the ignition but apparantly they can't use that. Is there any way to get a new one cut? |
06-13-2009, 01:17 AM
Lost Key
Jep, just take one of the lock to a reputable locksmith. They should be able to make one custom fit the lock within 24 hours.
06-13-2009, 01:25 AM
Lost Key
Do you know if they have key codes on the lock cylinders of my car? I think it would be cheaper to get one from Satan than it would a lock smith.
06-13-2009, 06:38 AM
Lost Key
I had a look on one of my old cylinders. There is nothing at all on the actual cylinder, however there is a 4 digit number on the arm that actuates the lock mechanism when you turn the key.
06-13-2009, 07:50 AM
Lost Key
Alright, that will probably (Hopefully) work.
Thanks. |
06-13-2009, 09:29 AM
Lost Key
That 4 digit number should be on the right side door locks arm.
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
06-13-2009, 05:56 PM
Lost Key
The locksmiths cost was about 25 euro including 2 extra keys..totally reasonable.
06-13-2009, 09:49 PM
Lost Key
S.K. Wrote:That 4 digit number should be on the right side door locks arm.Thank you so much, I appreciate it. |
06-17-2009, 07:44 AM
Lost Key
Just for the record, they can't use the code on the actuator, there is a code printed on the lock cylinder itself, passenger side.
It was hard to read, but the good ol folks at Toyo cut me one for cheap. Thanks everyone. |
Help! Lost tachometer, water t. gauge, alternator wont charg | Saber | 9 | 13,089 |
05-21-2012 08:06 PM Last Post: Saber |
Broke off the key in the ignition. | Aram | 5 | 5,233 |
10-29-2010 04:38 PM Last Post: Aram |
Completly lost.... | Spy | 23 | 21,326 |
11-13-2006 12:12 AM Last Post: Spy |
