Lowering Height
11-13-2006, 11:18 PM
Lowering Height
Hi,
I'm very confused about what lowering springs should i buy.
I want to lower my hachi about 4 to 6 cm.
I see many springs from different brands for sale but they only refer the spring rate and not the lowering height.
Anyone knows what is the lowering height of different spring brands?
I'm more interested in TRD springs, anyone knows how much they lower the car?
Thks
11-13-2006, 11:26 PM
Lowering Height
There are many lowering ones and few making sence. Too low/hard is making you mostly slower on the street, but looking good Smile.
Go for coilovers Wave .
"..el camino's aren't supposed to make sense, craziness is what makes the world go around." - Car & Driver, 1984
11-14-2006, 01:12 AM
Lowering Height
Can i fit those coil-over conversion kits with my koni sport shocks?
Like this from T3
[Image: AEU86 AE86 - Lowering Height]
11-14-2006, 10:53 AM
Lowering Height
Yes, you can.
Especially if you use lower spring/shorter shocks - coilovers are good idea !
11-14-2006, 11:27 AM
Lowering Height
Here's my old car on TRD 6 and 4.7 with AGX's
(the red hatch)
http://www.hachiroku.net
11-14-2006, 09:58 PM
Lowering Height
Quote:Especially if you use lower spring/shorter shocks - coilovers are good idea !
I got the stock ae86 struts and koni sport shocks for it. Is this a problem?
05m0515:
I like your lowering height but i think the rear should a little bit more high but maybe it's because the car is on a downhill
11-14-2006, 10:56 PM
Lowering Height
Just use regular springs for those koni's.. coilovers wont do any better, but the advatage of coilovers is that it's cheaper to buy springs and find a springrate you like.
11-14-2006, 11:07 PM
Lowering Height
Ok, Ivan
I'll try to find some suitable springs for my hachi
11-14-2006, 11:22 PM
Lowering Height
TRD springs make for a bone-jarring ride in the commonly available 8/6 front/rear springrate combo. They are also way too short for regular springs, you will be riding on the bumpstops more than is preferable. I'd suggest buying a complete set from 1 manufacturer (maybe swift, thay offer some).
If comfort is a priority, and you dont have big wheels that will scrape if the rise is too soft, then getting a pair of cheapo Cobra springs from ebay.de and adjusting the koni's to the desired firmness works fine too. This however is not the best you can get in terms of performance, and they will eventually sag a bit, but you cant really go wrong for 80 euro's..
11-15-2006, 10:36 AM
Lowering Height
Hum...
I found the website of Whiteline Suspensions.
Any one had already tried Whiteline Springs?
Ivan:
Do you know if eibach have lowering springs for the AE86?
I have them in my 106 S16 and i like them, they give some confort on a daily use and have a fair performance on the track.
  Gear end , drive pinion height filh 5 11,325 06-27-2013 12:29 AM
Last Post: filh
  Stock ride height xrgeorg 11 12,662 10-08-2011 07:38 AM
Last Post: xrgeorg
  lowering spring information HELP martyg 1 3,470 09-27-2011 01:56 PM
Last Post: martyg
  Car height, how much lower can it go.. Aram 13 17,192 05-16-2011 12:00 AM
Last Post: SekiguchiUeno
  Front bumper height MartinS 2 3,972 01-26-2010 04:13 PM
