MCNSPORT latest ae86 project **MUST SEE**
09-17-2009, 10:17 PM
Post: #51
Just simple question:
[Image: AEU86 AE86 - MCNSPORT latest ae86 project **MUST SEE**]
Why in the hell you didnt reworked IC inlets to go straight to the engine side instead of going to the top? This would saved you 1 bend on eatch side and saved some flow speed Smile
Everything else looks nice!
Ex-owner of JDM 83' Trueno Coupe
DCw Classic, classic cars restoration,
JDM wheels & parts import, sales.
http://www.facebook.com/DogCustomWorks
+37067170000
09-18-2009, 12:19 AM
Post: #52
Well I suppose it's a bit better then a front-mounted IC, but the lack of airflow is a minus. As you already said this is not a big issue for a drift car as you wont be using boost for extended periods of time.
A too big IC is a great heat-sink so will cool air down pretty good, but introduces much lag. Your V-mount seems to be a nice middle size.. big enough heatsink, not so big as to introduce lag.
I wouldnt choose this type of setup on a track car unless I could make sure that enough cold air flows through the IC. In your configuration only a bit of shroudingaround the IC and an exit vent in the hood would make this possible.
  MCNSPORT: Carina TA60 MCNSPORT.com 9 11,625 10-23-2012 10:15 AM
Last Post: Lightning
  MCNSPORT: D-Mac86 The Evolution MCNSPORT.com 19 27,627 07-27-2012 10:55 PM
Last Post: MCNSPORT.com
  few pics of my latest victim :) Dimitri 52 56,284 12-19-2010 12:18 PM
  MCNSPORT: Need for Speed D-Mac 86 MCNSPORT.com 14 18,557 12-03-2010 09:46 PM
Last Post: F20C
  The MCNSPORT.com RE86 - Rotary Powered AE86.. MCNSPORT.com 19 28,380 10-08-2009 08:56 PM
