MCNSPORT latest ae86 project **MUST SEE**
09-17-2009, 10:17 PM
Post: #51
Just simple question:
![]() Why in the hell you didnt reworked IC inlets to go straight to the engine side instead of going to the top? This would saved you 1 bend on eatch side and saved some flow speed ![]() Everything else looks nice! Ex-owner of JDM 83' Trueno Coupe DCw Classic, classic cars restoration, JDM wheels & parts import, sales. http://www.facebook.com/DogCustomWorks +37067170000 |
09-18-2009, 12:19 AM
Post: #52
Well I suppose it's a bit better then a front-mounted IC, but the lack of airflow is a minus. As you already said this is not a big issue for a drift car as you wont be using boost for extended periods of time.
A too big IC is a great heat-sink so will cool air down pretty good, but introduces much lag. Your V-mount seems to be a nice middle size.. big enough heatsink, not so big as to introduce lag. I wouldnt choose this type of setup on a track car unless I could make sure that enough cold air flows through the IC. In your configuration only a bit of shroudingaround the IC and an exit vent in the hood would make this possible. FABRICA MI DIEM, PVNC! |
MCNSPORT: Carina TA60 | MCNSPORT.com | 9 | 11,676 |
10-23-2012 10:15 AM Last Post: Lightning |
MCNSPORT: D-Mac86 The Evolution | MCNSPORT.com | 19 | 27,721 |
07-27-2012 10:55 PM Last Post: MCNSPORT.com |
few pics of my latest victim :) | Dimitri | 52 | 56,801 |
12-19-2010 12:18 PM Last Post: nmwisima |
MCNSPORT: Need for Speed D-Mac 86 | MCNSPORT.com | 14 | 18,668 |
12-03-2010 09:46 PM Last Post: F20C |
The MCNSPORT.com RE86 - Rotary Powered AE86.. | MCNSPORT.com | 19 | 28,497 |
10-08-2009 08:56 PM Last Post: MCNSPORT.com |
