MCNSPORT latest ae86 project **MUST SEE**
03-11-2009, 01:48 AM
Post: #41
Darren the best thing to try and do with people like him is ignore them, as after a while of being ignored they just give up. Well that's what i've found anyways. I'm liking the cars, and if I can afford it am gonna try and go over Ireland to see the Prodrift Ireland at some point.
(P.S- I have a mate who you talk to on msn quick often, also has the name of Darren, has been asking ya alot about the N2.)
DJ Thumbs up!
[Image: AEU86 AE86 - MCNSPORT latest ae86 project **MUST SEE**]
AE86 FTW!
03-19-2009, 10:52 AM
Post: #42
awesome work mate. Dont worry about old mate. He is a lil cut cause he has a sprinter with similar mods.. we also have to put up with is mindless lectures on HR.com.au
The car is not my taste of what a 86 should be, but fuck me this thing is amazing not so much the work (which is still impressive) but the detail and the lil things are fantastic i think only someone who actually drives their cars and drives them well and hard would know to put the lil touches and things into his or her builds as you have demonstrated in this one!
Keep up the good work and i might have to hit you up for a dash!!
Love AE86? Visit us @ HR
03-26-2009, 10:45 PM
Post: #43
Thanks guys
being hoping to get more progress done on this bit its been slow for a number of reasons
thanks mr.beau for the for the comments, we've learned a lot over the years and are more than happy to pass it onto our customers
darren
MCNSPORT.com
Jap, European, Drift, Drag, Circuit, Road, Race, Rally
Tel: +353 (0)2223334
Mob: +353 (0)866063716 (Darren) / +353 (0)876616567 (Peden)
E-mail: [email protected]
Web: http://www.mcnsport.com - NEW WEBSITE COMING: Feb, 2009!
05-26-2009, 05:37 PM
Post: #44
Custom MCNSPORT exhaust - (Exhaust used for custom system is: MCNSPORT Special Martelius 3" AE86)
Intercooler piping done - As well as Rad piping and new Jubiride Camber tops)
MCNSPORT Front AE86 Coilovers (Using AVO/MCNSPORT Front short-stroke inserts)
Fuel filler cap relocated and now goes through Perspex window
MCNSPORT AE86 CarbonFibre dash holesaw'd for new Defi guages
Fuel cell firewall templates for CarbonFibre panels
AE86 Coilovers modified with S14 mounting bush
Wiring loom preperation
Water temp sensor mounted on custom filler neck
MCNSPORT.com
09-16-2009, 07:01 PM
Post: #45
Keep it AE86 - Keep it MCNSPORT!
Darren & Peden
MCNSPORT.com
MCNSPORT.com
09-16-2009, 09:49 PM
Post: #46
awesome Smile If you ever need a hachi builder Smile
btw what I just don't understand is why to put the IC at that position? is it better for the airflow or something ?
And is the chassis adjustments strong enough to hold the s14 sub frame? And how much does the s14 sub frame weighs compared to the ae86 axle ?
I widened my arches in advance in case I wanted to use a different rear setup. So how "easy"is the S14 conversion ? Alignment etc?
Any more cars on the build numbers?
09-16-2009, 09:53 PM
Post: #47
robo, look how short the ic piping is Wink
09-16-2009, 09:58 PM
Post: #48
hmmz good point. but I am not a real brain in turbo cars. (acutally only know how to work a 4age NA Smile
So the shorter it is the better? But what about the tubing of the IC won't that heat up and take a way a bit of power?
09-16-2009, 10:38 PM
Post: #49
I can imagine the airflow being pretty shit without a vent to the hood.
The IC piping is not THAT much shorter to make it worthwile, more bends are introduced this way but it's certainly something different.
It probably doesnt matter much since the intercooler works more like a heat sink for short bursts of power use. Meaning that it soakes up all the heat while your giving it hell, only to cool off slowly in the bits in between. No intercooler is so efficient that it immediately cools down from the passing airflow.
09-17-2009, 08:44 PM
Post: #50
There are many advantages of a v mount intercooler system
the distance from the turbo to the throttle body is half compared to a front mount which equals less lag
99% of people run too big of a front mount intercooler and this can cause more lag again
Drift cars are only used in short bursts as opposed to many laps and less lag is more important then searching for cooler intake temps
@Ivan141, are you saying that this setup has more bends than a front mount intercooler???
@Robokill, yes the mounts are strong enough? the ae86 axle is still lighter than a subframe setup and it is a rear pain to fit it takes many hours of measuring and cutting and welding and measuring again
MCNSPORT.com
  MCNSPORT: Carina TA60 MCNSPORT.com 9 11,569 10-23-2012 10:15 AM
Last Post: Lightning
  MCNSPORT: D-Mac86 The Evolution MCNSPORT.com 19 27,550 07-27-2012 10:55 PM
Last Post: MCNSPORT.com
  few pics of my latest victim :) Dimitri 52 56,139 12-19-2010 12:18 PM
  MCNSPORT: Need for Speed D-Mac 86 MCNSPORT.com 14 18,465 12-03-2010 09:46 PM
Last Post: F20C
  The MCNSPORT.com RE86 - Rotary Powered AE86.. MCNSPORT.com 19 28,248 10-08-2009 08:56 PM
User(s) browsing this thread: 14 Guest(s)
