MSD 8980 setup - which wire does the dizzy connect to?
11-19-2011, 03:20 PM
Hi all,
I'm in the final stages of my carbed 4AGE setup but I need to know which cable goes from my 4age dizzy to the MSD 8980 timing computer. the dizzy has 3 wires going out a white, blue and red which needs to connect to the white going into the MSD timing computer but which one? thanks ![]() |
11-22-2011, 04:27 PM
anyone. its a very common mod when carbing a 4age. someone must know
11-22-2011, 06:29 PM
Please post a wiring diagram of the MSD.
What signal does the MSD require? RPM or ignition impulse? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
11-22-2011, 06:44 PM
It depend of your dizzy (and the signal that the MSD need)
VIOLET wire from MSD should be connected to RED OR BLUE wire from the dizzy (I would say the RED) and the GREEN wire to the WHITE from dizzy. BTW I don't run on carb nor MSD, I just read the MSD manual so I may be wrong. Try, since it's a VR sensor they're is no risk to damage anything ![]() |
11-22-2011, 06:47 PM
it requires an ignition pulse.
which upon further research means it will be using the green & violet cables: http://www.msdignition.com/WorkArea/Down...x?id=16233 still not sure what it needs to connect to in the way of the dizzy ![]() |
11-22-2011, 06:51 PM
open your dizzy and look which wire goes to the sensor front of the wheels with 4 teeth -> this is the wire you will need
![]() (the white wire is the ground for both sensors) |
11-22-2011, 06:58 PM
cool I had a look when fitting the rest of the unit and if its the 4 teeth sensor then i know which cable to use. thanks
11-22-2011, 07:02 PM
1 tooth = 1 spark so 4 cylinders = 4 teeth
20v BT - which oil pump? | Mylesmck | 4 | 2,901 |
Rim width. Which is best.... | Dino86 | 5 | 6,903 |
Anyone know what this plug does? | Super86 | 3 | 6,362 |
08-01-2016 03:57 PM Last Post: Nakilad |
which connector is this | ditn | 7 | 7,850 |
07-27-2015 11:24 AM Last Post: pack |
Haslbeck front spoiler, which foglights? | wouter86 | 2 | 5,160 |
02-15-2015 11:14 AM Last Post: ditn |
