Machining Pistons to run 20v head... And FCR's on a 20v?
09-11-2013, 07:17 PM
Anyone up on this?
I might be running a 20v head on my 16v, is pocketing a high comp 16v forged piston to take the 5th valve something that can be done? Also, anyone ran FCR's on a 20v head? This head has no VVti to worry about, so my current FCR's should theoretically go on with a new inlet manifold and a Dizzy relocation kit.. Right? Ta! Driftworks - JSPFab.com - DangerStyle - NightSpirit |
09-15-2013, 01:08 AM
![]() Quote:At the time I built this engine no one did decomped 5 valve pistons,One Aussi did this when building a 20V turbo engine, so I guess it is possible. Might pay to get an old 16V piston and drill a few holes to see how much meat there is in the dome where you need to cut... and measure the valve to piston clearances very carefully. Cheers... jondee86 |
82mm Stock compression Pistons | apardal | 4 | 2,940 |
Where to run the factory antenna cable | andyling | 2 | 3,771 |
09-30-2020 12:31 PM Last Post: andyling |
Small Port 10.3 Pistons | Alex170984 | 1 | 4,416 |
How to install 20V ITB on 16V head | Mr.komp | 7 | 12,007 |
20v block with 16v head and internals possible? | ditn | 3 | 7,164 |
08-12-2014 09:19 PM Last Post: ditn |
