Max ignition Advance?
09-30-2007, 10:37 PM
Just wondering what is the maximum ignition advance on a large port 4AGE, I'm heading to the rolling road next week, finally getting the car set up on the ITB's. I am currently running 31 degrees advance at full load, high revs.
Cheers Ivan 1972 MG Midget - AE86 Engine, Ford Anglia Axle - Escort LSD - Live the Dream!!1 |
10-01-2007, 07:56 PM
on my blacktop , when it was na, i used to run 38 degrees at 8500 rpm, with the lowest around 6k rpm, that was around 33 degrees,
This was on 98 octan, but i think that blacktop can run a bit more advance over the bigport 16v /Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
| Ignition switch plug and wires | Blaze0010 | 3 | 2,204 |
| Anyone got Max Orido's Magical Fuse? | banpei | 7 | 6,354 |
02-08-2024 11:09 AM Last Post: banpei |
| 20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 16,452 |
| extracted freedom ecu 16v ignition map | ditn | 7 | 11,073 |
| 4AGE 20v Ignition Lead Length | mad.matt | 3 | 7,927 |
10-01-2014 03:43 PM Last Post: mad.matt |
