Max lift on Vitz valve lifters
12-25-2013, 07:39 PM
Hi
Thinking of converting to the Vitz valve lifters. Do you know if these will also allow a higher lift than the original?
- Niels
Conversion:
http://www.club4ag.com/faq_and_tech_page...uning.html
12-25-2013, 07:56 PM
I've seen conversations with the Yaris/Vitz with 11mm lift so yea they allow higher lift. Planning this conversation on my other engine which I rebuild at the moment too Smile
Daily Beater: Civic EG5
Work in progress Car: AE86
12-26-2013, 02:10 AM
Those lifters are the ones to choose for high lift cams! Pretty sure you get the valve springs to bind 1st, before the bottom of the lifter hits the head. Thumbs up!
1979 Toyota Corolla KE35
1983 Toyota Corolla AE86
1985 Toyota Corolla AE86
12-31-2013, 01:14 AM
is it just the 1.5 followers are used or can 1.3 be used as well. thanks
01-01-2014, 03:44 PM
It should be the 1.0 you use
01-01-2014, 03:46 PM
Nobody knows how much lift these lifters will accomodate?
01-02-2014, 03:32 AM
From what I can see on the interwebs, the total height of the shimless
bucket is about the same as the bucket with shim. It also appears that
the thickness of the shimless and the bucket plus shim are similar. So
in theory at least, the maximum lift with either type should be much the
same. But unfortunately, I don't have buckets available for measuring.
Lighter weight will be helpful for higher rpm's, and no loose shim is good
for higher lift above 8.5mm or so. If you go above 10mm lift I believe
you have to notch the head for clearance. Plus you will need TRD or
similar springs, and you will need to check when coil bind occurs.
There is very little reliable information on exactly how much lift you can
get with any particular combination, and apparently there can be small
variations in dimensions between heads. Not much help I know, but if
you plan on pushing the limits for a 4AGE, you are going to have to get
hold of a sample Vitz bucket and do the measuring for yourself. That way
you can be sure it's going to work Smile
Cheers... jondee86
01-02-2014, 05:41 AM
Pretty much the same height:
[Image: AEU86 AE86 - Max lift on Vitz valve lifters]
They don't allow higher lift because of their height but because they don't have an upper shim Wink
Higher lift with an aggressive ramp will throw the shim out of their buckets...
BTW, the OEM springs will NOT work properly past ~8.5mm.
So the first upgrade should be the springs before the buckets.
01-02-2014, 10:27 AM
pretty much all said already. but to sum it up again in stages.
all stock parts will limit lift to about 8.5mm due to th springs binding
better springs, rest stock will limit lift to about 9-9.5mm due to risk of the cam grabing the shim and leading to disaster.
better springs and solid lifters: lift will be limited by the head design due to the cam hitting the casting around the lifter hole.
if you change all the above accordingly you can go all the way up to around 13mm of lift
I run springs and solid lifters from the yaris (1SZ-FE) with 9.5mm lift - might switch to 11mm once I get it dynoed if there is enough room in the rev range left.
PS: If you go with the yaris lifters I have a set of the thinnest ones (8 pieces) to use for measurement so you can order the right size. You'd have to pay for postage back and forth.
AE86 ex-daily
  Anyone got Max Orido's Magical Fuse? banpei 7 4,248 02-08-2024 11:09 AM
  4AGE Valve Buckets Scored Steller Engineering 2 1,078 10-06-2023 05:34 PM
Last Post: Steller Engineering
  20 Valve Blacktop smoking after engine flush - why? RolanTHUNDER 2 1,678 11-30-2022 12:09 PM
Last Post: RolanTHUNDER
  HKS valve springs totta Crolla 3 2,522 05-25-2022 10:24 PM
Last Post: oldeskewltoy
  Valve clearance leon205gti 7 9,038 11-25-2016 03:24 AM
User(s) browsing this thread:
