Maybe problem with TRD shock absorber and springs
10-10-2011, 12:04 AM
A thing , but your Ae86 with Trd shock absorber, bounce a little if you push it?
10-10-2011, 12:41 AM
I don't have trd , i have D2 coilovers.
You can find alot of info on trd suspensions on google. My car is on the hardest setting. Even with 3 people pushing on it, you can't make it bounce. ハチロク |
10-10-2011, 10:53 AM
It may be sitting on the bump stops in the back and the front may have run out of damper travel.
10-10-2011, 06:30 PM
I have 8/6 springs, and HTS dampers. YES, my suspension is hard. NO, it doesnt bounce, even one bit!
AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
10-11-2011, 12:04 PM
OEM (factory) springs are something like 1.9/2.0kg/mm front/rear. You
probably have the classic "drift" springs of 8.0/6.0kg/mm. I have about 3.2/3.0kg/mm and that is acceptable for rough roads. At a guess I would say 4.5/4.0kg/mm is about the limit for rough roads if you have to drive more than a km or two. Of course, there are people who will say that 8/6 is comfortable.... So you either have to get used to your teeth rattling, or look for some softer springs. Cheers... jondee86 |
10-12-2011, 06:43 PM
I must unmount and see which kind of springs I have.
10-12-2011, 07:31 PM
Before you unmount them check as above the bumpstops.
Once they are unmounted you can use this calculator to work out the approximate rate of the spring if it is not obvious. http://www.stockcarproducts.com/pstech10.htm An analogue brain in a digital World |
10-12-2011, 07:59 PM
Just checked my d2 specs. I have 7.4kg/mm in the front and rear is 6.2kg/mm .
ハチロク |
10-12-2011, 08:30 PM
@ totta crolla: thanks for the link, it's very useful
@ zenki: do you have a photo of side of your hachi? |
10-12-2011, 08:44 PM
:wink:
ハチロク |
HKS valve springs | totta Crolla | 3 | 2,001 |
AE86 w/MX-5 swap, maybe?? | cke70 | 13 | 13,469 |
05-31-2016 08:30 PM Last Post: cke70 |
Springs from other vehicles?? | FanIsHere | 16 | 14,026 |
05-17-2016 09:12 AM Last Post: FanIsHere |
Oil leak (maybe a cylinder head gasket?) | max_ae86 | 15 | 16,529 |
11-30-2013 03:59 AM Last Post: jondee86 |
3rd door support gas springs (stay) - worn out | max_ae86 | 5 | 5,985 |
09-01-2013 03:20 PM Last Post: Jezza_hr |
