Maybe problem with TRD shock absorber and springs
10-10-2011, 12:04 AM
A thing , but your Ae86 with Trd shock absorber, bounce a little if you push it?
10-10-2011, 12:41 AM
I don't have trd , i have D2 coilovers.
You can find alot of info on trd suspensions on google.
My car is on the hardest setting. Even with 3 people pushing on it, you can't make it bounce.
ハチロク
[Image: AEU86 AE86 - Maybe problem with TRD shoc...nd springs]
10-10-2011, 10:53 AM
It may be sitting on the bump stops in the back and the front may have run out of damper travel.
10-10-2011, 06:30 PM
I have 8/6 springs, and HTS dampers. YES, my suspension is hard. NO, it doesnt bounce, even one bit!
10-11-2011, 12:04 PM
OEM (factory) springs are something like 1.9/2.0kg/mm front/rear. You
probably have the classic "drift" springs of 8.0/6.0kg/mm. I have about
3.2/3.0kg/mm and that is acceptable for rough roads.
At a guess I would say 4.5/4.0kg/mm is about the limit for rough roads
if you have to drive more than a km or two. Of course, there are people
who will say that 8/6 is comfortable.... Smile So you either have to get used
to your teeth rattling, or look for some softer springs.
Cheers... jondee86
10-12-2011, 06:43 PM
I must unmount and see which kind of springs I have. Thumbs up!
10-12-2011, 07:31 PM
Before you unmount them check as above the bumpstops.
Once they are unmounted you can use this calculator to work out the approximate rate of the spring if it is not obvious.
http://www.stockcarproducts.com/pstech10.htm
10-12-2011, 07:59 PM
Just checked my d2 specs. I have 7.4kg/mm in the front and rear is 6.2kg/mm . Smile
ハチロク
10-12-2011, 08:30 PM
@ totta crolla: thanks for the link, it's very useful
@ zenki: do you have a photo of side of your hachi?
10-12-2011, 08:44 PM
:wink:
ハチロク
  HKS valve springs totta Crolla 3 2,001 05-25-2022 10:24 PM
  AE86 w/MX-5 swap, maybe?? cke70 13 13,469 05-31-2016 08:30 PM
Last Post: cke70
  Springs from other vehicles?? FanIsHere 16 14,026 05-17-2016 09:12 AM
Last Post: FanIsHere
  Oil leak (maybe a cylinder head gasket?) max_ae86 15 16,528 11-30-2013 03:59 AM
Last Post: jondee86
  3rd door support gas springs (stay) - worn out max_ae86 5 5,985 09-01-2013 03:20 PM
Last Post: Jezza_hr
