Megasquirt DIY Fuel/Ignition Controller ECU
10-05-2004, 10:31 PM
Ahh,...I must have misread...I thought you where goint to turbo a GZE. Well, I've been playing with the idea of turbocharging a regular 4age myself so this is still a point of interest for me. I have a block in need of a rebuild, and if I'm going to need new pistons they might as well be wiseco low compression pistons right? I think it should be able to hold a moderate amount of boost on the stock internals. Some kind of DIY fuel and spark controller + wideband lambda sensor would do the trick.
Messages In This Thread |
Megasquirt DIY Fuel/Ignition Controller ECU - Speedy - 10-05-2004, 08:15 PM
[] - Ivan141 - 10-05-2004 10:31 PM
Ignition switch plug and wires | Blaze0010 | 3 | 220 |
20v Silvertop stock ignition timing and fueling maps | Lykowsky | 5 | 13,338 |
DIY: a quick outline on why & how to set pinion angle. | assassin10000 | 9 | 18,196 |
extracted freedom ecu 16v ignition map | ditn | 7 | 8,793 |
4AGE 20v Ignition Lead Length | mad.matt | 3 | 6,581 |
10-01-2014 03:43 PM Last Post: mad.matt |
