headgasket thickness
05-22-2006, 07:48 PM
I've searched on technical forum , but didn't find an answer to my question .
As I encountered problem with my 16v head , the headgasket must be changed. I saw that it's possible to get different thickness, with metal layers and that compression ration can be changed , just with that use .That sound to good to be real ... But I don't know the stock thickness? Any help welcome Filh Filh Save the RWD cars |
05-22-2006, 10:31 PM
The stock thickness is 1mm. There is couple company make thinner headgasket for 4age 16V.
The TRD have 0.8mm (11115-AE814) & 0.5mm (11115-AE824). TODA have 0.6mm (12251-4AG-006), 0.8mm (12251-4AG-00 and 1mm (12251-4AG-010). Those headgasket are all make by metal. On the price, TRD is cheaper than TODA. If you need pricing of all those, Please give a PM to SYM (P.A.S.S.) Thank you. Maxwell Arancon Vice President PASS RACING INC 148 S.8th Ave, Unit-F City of Industry, USA [email protected] http://www.passracing.com |
05-22-2006, 11:57 PM
thanks for your clear and quick response
filh Filh Save the RWD cars |
max brake disc thickness ae86 caliper+heel and toe question | ditn | 26 | 26,606 |
10-02-2012 05:00 PM Last Post: ditn |
OEM sway bar thickness ?? | T_AE86 | 5 | 11,737 |
08-07-2011 04:05 PM Last Post: Hachi |
oem head gasket thickness? | Melo | 6 | 5,960 |
05-22-2009 10:46 PM Last Post: Melo |
Silvertop Headgasket? | byd1380 | 3 | 4,052 |
01-05-2009 06:02 PM Last Post: byd1380 |
AE86 Factory Swaybar thickness?? | hachirokuGTV | 3 | 4,130 |
10-21-2008 08:08 PM Last Post: hachirokuGTV |
