Megasquirt talk (split from robokills project thread)
03-07-2006, 06:23 PM
Denmark Wrote:I did have MS on th ered turbo ae86,and it was working great, Hey Skassa.. I got VEMS om my car and am also gona install VEMS on my EA86. Are you bying yours together with PeterJ? I heard the guy who bought your old turbo-AE86 isn't driving it too I don't think VEMS is too expensiv.. for ~400EUR the Wbo2 is inluded and most of the board is assembled (+$ for total assembling) and tested before it's beeing shiped out. When you got a Wbo2 the computer can also do "closed loop" under bigger load (other AFR).. |
03-07-2006, 07:04 PM
If you want to do a clean install with plugging the MS directly onto the car's own wiring harness, you might be interested in knowing that the yellow receptacle on the standard AE86 ECU is AMP pulse lock connector p/n 1-172489-7, specifications available here;
http://catalog.tycoelectronics.com/TE/bi...&IDS=44546 http://www.onlinecomponents.com has it listed on their catalog, price is $19 per unit in quantities under 50. If you need the plugs, their AMP part numbers are as follows; 10pin; 172315-7 18pin; 172316-7 14pin; 172354-7 Contacts inside the plugs are p/n 170352-1. I still need to find the part number for the large connector located in the engine bay, mounted to the middle of the firewall. This connector attaches the engine harness to the rest of the car so when building a custom harness for the engine, it would be nice to be able to connect it cleanly to the rest of the car at this location. |
03-08-2006, 12:31 AM
Good idea. Though i might think of removing a set of connectors of my original computer. (hmmz maybe not)
I'll see if i can dig it up :-D Thing that slows me is still money :-( Wanting the MS to run properly i think i need alot of bench time to fine tune it so i need to get some info about it. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-08-2006, 03:08 AM
You won't need any benchtime..They don't even have a lot of steady state benches, so theres not a lot that a bench can do that you can't do yourself on the road with an uphil+handbrake..
With a wideband and logger it should be no problem to road tune the car better then anyone could on a dynojet.. A wheel to steer the front of the car A pedal to steer the rear |
03-08-2006, 01:25 PM
anyways nohachi i want bechtime to see my outcome power on the wheels :-)
03-08-2006, 01:33 PM
NoHachi Wrote:You won't need any benchtime..They don't even have a lot of steady state benches, so theres not a lot that a bench can do that you can't do yourself on the road with an uphil+handbrake..True.. but ignition is a hole lot harder. You can set your ingnition after when it starts knocking but you doo need benchtime to know when you got best power (of course still without knocking). |
03-08-2006, 01:43 PM
I've been browsing through the whole VEMS site a bit...really damn cryptic website. But it does have nice features. I cant find anywhere that it comes with a WBO2 sensor...but the controller is indeed built in. Add to that all the other options that you would most likely want and you end up at 550+ euro's at the very least. Not saying it's not worth it, but you can get a megasquirt to do most of the same things for less. Especially if you split the costs of the WBO2 and just run narrowband once you've got it tuned right.
03-08-2006, 05:54 PM
Anybody knows simple and cheap way of monitoring knock in engine?
I'm using this method http://bagpuss.swan.ac.uk/horsham-develo...nation.htm but thanks to my screamer pipe in engine room I can't hear nothing, so I need some kind of electronic device. Btw good info about knock http://www.stanford.edu/~bmoses/knock.html Drifting - best fun you can have in your car with your pants on! |
03-08-2006, 07:22 PM
Ivan141 Wrote:I've been browsing through the whole VEMS site a bit...really damn cryptic website. But it does have nice features. I cant find anywhere that it comes with a WBO2 sensor...but the controller is indeed built in. Add to that all the other options that you would most likely want and you end up at 550+ euro's at the very least. Not saying it's not worth it, but you can get a megasquirt to do most of the same things for less. Especially if you split the costs of the WBO2 and just run narrowband once you've got it tuned right.It dos'nt come with a who2.. but 450EUR (wbo2 included ~66EUR) should do it if you mount the transistors and connectors you selv.. but yes, it depends on what you need and MS can bee made cheaper without wbo2. |
03-08-2006, 11:51 PM
Zax,
Dahm, you run that car rich,even the Impreza were i was running 1,6 bar did not have to be that rich(and that is engine need it rich), Other then that, i also have a Techegde WBO2 the one in the green alu case, this is what i use when i map other cars. the VEMS i´m getting is with a discount,as it´s a groupbuy, here in Denmark. So it will be 3000Dkr,all in including the lsu4. As knock montering i have always been using this : http://www.link-electro.co.nz/knocklink.html On the Impreza,i had i permently mounted in the speedo, Pic here there is a adjustment screw on the top,on the impreza this had to be on max sensitivity,then it was spoot on , when testing it, the same way as you,but this way you can always see it, The red light will flash long before you can hear it normaly,but with the ear defenders, it´s spot on. Max sensitivity was also spot on on the Turbo AE86. Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
Lets talk engine mounts | kazi | 6 | 7,443 |
08-31-2017 12:46 PM Last Post: parrot |
Oil plug thread size is M18x1.5 ???? | Dino86 | 5 | 9,101 |
AE86 Temperature gauge sender thread? | 4AGE FORD | 1 | 3,782 |
03-20-2011 01:25 AM Last Post: 4AGE FORD |
Megasquirt I v3.0 and toyota distributor/igniter | harkes | 12 | 33,173 |
10-02-2009 01:19 PM Last Post: Chrisso |
MegaSquirt and Direct Coil Control | harkes | 1 | 2,961 |
06-25-2009 06:19 PM Last Post: harkes |
