Mintex pads
08-17-2005, 01:34 PM
Mintex pads
Hi All.
I have a problem with the Mintex pads,they tend to fell out of the caliper mounting bracket,resulting in a long travel on the pedal. it´s like the the place were the pads is held in,is to short! I have now just gotten the rear pads,and i can see that they are made the same way, they taps that are on the pads bend back. Do any of you know what i´m writing?, And if,do you have a solution to the problem? Regards, Skassa Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
08-17-2005, 02:48 PM
Mintex pads
Are you using all the mounting clips?
I usually stuggle to get brakepads in with those stupid little clips, so they might help to keep the pads in position. FABRICA MI DIEM, PVNC! |
08-17-2005, 04:00 PM
Mintex pads
Yep,
I even got some new ones,but it´s on OE pads the pad is all flat ,if it´s put on a table with the backside down(it will be flat on the table) If i do the same with the Mintex pad,the ends, are on the table,nut not the hole pad lying flat on the table. Hmm, I guess that none of you have the same problem Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
08-17-2005, 04:43 PM
Mintex pads
Last time i changed the rearpads (not mintex) they had the same bend to... I guess they have that bend, because the pads is a bit thinner than the OE ones. I bought new mounting clips for my Mintex, and havent got any problems so far
08-17-2005, 09:00 PM
Mintex pads
Hmm,
It´s just that the clips will tilt,when that pads are outside the Caliper mounting bracket, Last time when i took off the 1144 and put on the 1155mthe pads were realy messed up ,becourse they had only been pushed against the disc in the top of the pad Thanks, Any fool can go fast in a straight line. VEMS Blacktop 4AGTE20V 272hp/350nm """www.turbotoys.dk""" |
Problems Mintex M1155 pads | Dino86 | 9 | 8,899 |
07-04-2017 11:22 AM Last Post: totta Crolla |
Brake PADS:) | Mux213 | 32 | 42,891 |
11-08-2016 04:55 PM Last Post: pack |
Mintex brake pad MDB1193 | Dino86 | 9 | 9,145 |
02-27-2014 11:26 PM Last Post: Dino86 |
Brake Pads | |BUDA| | 8 | 10,431 |
04-16-2013 08:30 PM Last Post: damusto |
endless brake pads part number | Jango_Fett | 2 | 5,192 |
10-14-2009 05:54 PM Last Post: Jango_Fett |
