Modify the upper trailing arms
04-14-2009, 10:07 PM
I am building my AE86 for trackdays, (grip race), and I wondered how I can modify the upper trailing arms so the are more horizontal, when I have lowered the car. The arms actually hits the metal on the bracket now.
I thinking to move the bracket a bit up, but I have to reinforce it a lot to keep it stable. I borrow a picture here: http://i117.photobucket.com/albums/o65/j...008269.jpg
I have also thought to use equal lenght traling arms, but its a bit difficult to get it right. Like this guy here: http://img187.imageshack.us/img187/3112/cimg0925nw3.jpg
I'm not so happy tho do this operation, as I might will use the car as normal daytime car later. But if its realy nesesary to build these trailings arms boxes, I will do it.
The lower trailing arms can be horizontal just fitting some tractions brakets.
Does anybody have an idea what should be the best choise?
Project AE86 now begun.
Cars I have owned:
Toyota Starlet EP91 1,3 16v Turbo, 200hp
Toyota Starlet EP71 1,3 12v Sport
Mercedes 207D camper, 1977.
Toyota Starlet EP70 with a 174hp Silvertop 20v See video here:
http://videos.streetfire.net/search/Star...079edc.htm
Toyota Corolla AE101 with a 164hp Silvertop 20v. (Evolution bodykit and candycolor paint).
Volvo 240 2,1 (The only car I have maked money on).
Toyota Corolla EE90 (my first car)
04-15-2009, 09:28 AM
I'm going for the equal length arms in my car and I'm currently building the housings for the new brackets (link). It's going to be a dedicated track racer though, so there's no need to compromise.
One possibility might be not using equal length arms, but only slightly longer upper arms with a smaller housing protruding through the floor. This would make it possible to carve a bit of foam off the back seat and still be able to mount it back on the car.
This article is a pretty useful read when modifying the rear axle linkages:
http://www.afcoracing.com/tech_pages/4link.shtml
04-20-2009, 03:34 PM
Thanks for the link. It seams pretty difficult to figure out, where to drill the holes in the new box.
If I go for the full Racecar, I can also get rid of the sparewheel and make room for a rear diffuser instead.
This one I have to sleep on :wink:
Cars I have owned:
04-21-2009, 07:52 AM
Hey Jimmi! You can make it drive very well without using equal length arms. I would start off stock untill you decide on a fully built race car Thumbs up!
[Image: AEU86 AE86 - Modify the upper trailing arms]
  Broken 20v upper timing belt cover chip 2 5,104 07-16-2012 07:11 AM
Last Post: Jan Pedersen
  lower control arms (lca's) totta Crolla 4 6,364 05-11-2010 08:59 AM
  Ke70/Ae71 rear upper shock mount inner panelthe same as AE86 adamsaiyad 1 4,874 01-20-2010 10:21 PM
Last Post: adamsaiyad
  Adjustable Rear trailing arm/rear 4 links? lolali 1 5,289 10-03-2009 05:17 PM
Last Post: lolali
  i have the wrong arms on my 86 Poison 6 7,203 03-09-2006 02:16 PM
Last Post: mr monster
