Mumford link
11-26-2013, 09:17 PM
Mumford link
I had the idea to develop an affordable mumford link kit for the ae86 chassis a good while ago. im seeking challenges in suspension development and if theres interest for this, i would go for it.
if you dont know what im talking about, this is a panhard rod alternative, live axle lateral motion control, the best possible solution so far. even better than watts link. -no sideways motion, only up and down. -most important advantage is the control over the rear roll center. with a panhard rod, the roll center isnt fixed, could be anywhere along the panhard rod. with watts link, the roll center is fixed to center but it is still high above the ground. with mumford link, you can set your rollcenter close to ground level or even below it. result should be a much better traction and more predictable behavior at the rear. could help for rallying and track racing. let me know what you guys think! ![]() |
11-27-2013, 01:57 AM
Mumford link
![]() AE86 GT - SR20DET BlackTop //// Trackday beater Citroen C4 Coupe VTR - 1.6HDi //// Streetcar |
11-27-2013, 05:05 AM
Mumford link
will it be simply bolt-on?
11-27-2013, 09:01 AM
Mumford link
kawo Wrote:will it be simply bolt-on?axle side: bolt-on, chassis side: weld |
4 Link setup and Traction brackets | Jezza_hr | 5 | 10,653 |
07-21-2014 09:12 PM Last Post: Bean |
Wanted: Link to Beams Blacktop engine manual pdf | irishtwincam | 7 | 9,164 |
01-03-2014 11:31 AM Last Post: irishtwincam |
T3 5 link kit | Eric | 1 | 3,403 |
02-25-2010 09:19 PM Last Post: Eric |
Stock 4-link lengths? | NoHachi | 14 | 22,638 |
11-24-2009 10:54 PM Last Post: boo50 |
Rear link bushes | totta Crolla | 3 | 4,644 |
02-04-2008 12:32 PM Last Post: totta Crolla |
