Mux213 Levin GTS
09-22-2004, 10:40 AM
Mux213 Levin GTS
Whats a distribution belt? If you meen timing belt, its fairly easy. There are marks on both belt and cam gears Smile
09-22-2004, 10:51 AM
Mux213 Levin GTS
Hey Jan,
yeah timing beltSmile and I know its fairly easy, I've read through the procedure a couple of times when I was tinkering with a CRX but I have actually never done it nor do I have a manual at this time. Most likely I will be able to do it by myself once my haynes manual is in (still looking for a toyota manual copySmile) . I just want to make sure I don't do it wrong, be kinda nasty if I dont line it up correctly or dont tention it correctly.
I'm also thinking about leaving the dust cover off and spray painting the camshaft sprockets in a nice metalic blue color (only front surface). Anyone know if this has any unwanted side effects?
09-22-2004, 11:51 AM
Mux213 Levin GTS
As I said earlier: leaving the covers of allows debries to reach the timing chain etc etc. Unless you are building a show car i would let this particular rice boy modification pass.
Start bugging Kristian about his see-through cover, that would get you 90% of the look without the risk of ruining the engine.
09-22-2004, 11:52 AM
Mux213 Levin GTS
NoHachi,
Sorry I must have missed that postSmile
@Kristian
I WANT!Smile
09-22-2004, 11:12 PM
Mux213 Levin GTS
I've only done a timing belt change when my engine was still in the shed, waiting for installation. It couldnt be more easy. First you align everything for top dead center on the nr 1 cilinder. Under the oil filler cap you should see an indentation in the camshaft when the piston is at tdc on the correct stroke. After that you just put the car in gear on handbrake, get the pulley bolt off (which can be a bitch sometimes..airtools are great for this one). Remove the tensioner, install the new belt tightly and in the correct direction. Install a new belt tensioner!
That should be it..lot easier to do on an ae86 than it is on a CRX I think.
09-23-2004, 07:34 AM
Mux213 Levin GTS
Hey Ivan,
Seems straight forward enoughSmile
And yes, I got a new tentioner aswellSmile
09-23-2004, 04:50 PM
Mux213 Levin GTS
Yeah, sanded and spraypainted the old grill last night! Will get pictures online when I get it back on the car.
Tomorow is APK day (dutch MOT) so wish me luck guys!
09-23-2004, 04:57 PM
Mux213 Levin GTS
good luck!
09-23-2004, 06:48 PM
Mux213 Levin GTS
mux213 Wrote:Tomorow is APK day (dutch MOT) so wish me luck guys!
Good luck! Smile
Mine (the mitsu) is due next tuesday. Undecided
09-23-2004, 06:53 PM
Mux213 Levin GTS
Good luck...you should have a pretty good idea about what things might pop up at the MOT since you know your way around cars a bit. My main problems usually seem to be rust, tires, exhaust gasses and electronics.
Worn steering knuckles and wheel bearings arent uncommon as well if the car hasnt been maintained for a while.
[edit] How could I forget the ol'exhaust...it's as if it's made of swiss cheaseSad [/edit]
Lightbulb Deaty's GTS Project Deaty 9 5,231 04-27-2021 06:10 AM
Last Post: Deaty
  1985 Corolla GTS Project mattscar 5 10,747 01-30-2011 07:30 AM
Last Post: mattscar
  My SR5 to GTS Restoration Conversion. Lofty 15 19,810 09-25-2009 06:52 AM
Last Post: Lofty
  My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) ryceboy_124 4 22,655 08-05-2009 04:25 PM
Last Post: Eric
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 75,406 03-16-2009 10:02 PM
