Mux213 Levin GTS
04-19-2005, 01:48 PM
Post: #151
Mux213 Levin GTS
How does it sound mux? Too loud?
04-19-2005, 02:59 PM
Post: #152
Mux213 Levin GTS
Dorito,
It sounds pretty ok actually. Inside the car I dont notice any difference, outside the car you can hear this exhaust rattle a bit more, its a bit more raw sound, but it really isn't that different then my old 'exhaust'. Just looks a hole lot betterWink
I do get some more looks strangely enough, maybe at higher speed people driving next to me do get treated to more music from my exhaustSmile
Driving through a tunnel with the window open is the best thoughSmile
04-19-2005, 06:05 PM
Post: #153
Mux213 Levin GTS
mux213 Wrote:All I need now are blue seatbelts (instead of the brown ones)
How about black seatbelts? I have a set i the basement... :wink:
04-20-2005, 10:52 AM
Post: #154
Mux213 Levin GTS
mux213 Wrote:Driving through a tunnel with the window open is the best thoughSmile
Schiphol tunnel by any chance? Tongue
04-20-2005, 10:19 PM
Post: #155
Mux213 Levin GTS
knudsen,
remind me to put a picture up about what the MOT guys did to my seat belt to get the car through MOT....
Jon probably has some blue ones for me btwSmile
banpei, haven't tried that one yet actually...Smile
04-20-2005, 11:00 PM
Post: #156
Mux213 Levin GTS
Mux, im now giving you a reminder, to put up a picture about what the MOT guys did to your seatbelt, to get the car through MOT... Big Grin
07-02-2005, 01:12 AM
Post: #157
Mux213 Levin GTS
Hmmmm, I still need to post that seatbelt pictureWink
Anyways, tonight I finally found out whats wrong with my exhaust... Between the exhaust manifold and the 2-1 part, the exhaust was held together with just 1 bolt and nut! And that nut had started to come loose!! I could just move them appart from eachother!
There is also no gasket between these two parts!! I would a second bolt and bolted it all back together, going to find a 3rd bolt and see if I can get a real gasket for it and that should solve my exhaust problems for the time beingSmile
07-02-2005, 10:49 AM
Post: #158
Mux213 Levin GTS
mux213 Wrote:There is also no gasket between these two parts!! I would a second bolt and bolted it all back together, going to find a 3rd bolt and see if I can get a real gasket for it and that should solve my exhaust problems for the time beingSmile
Often there are 2 metalized rings instead of one gasket. Use studs instead of bolts and keep in mind that these parts heats !!!
07-02-2005, 12:03 PM
Post: #159
Mux213 Levin GTS
Jamie,
yeah I am worried about that, I'm not sure where to get the best things to bolt it up. What I have now is just temporary, eventually I'll need to take the 2-1 part off and fix it correctly. Also first need to get those rings somewhere because I think they are missing...
07-02-2005, 12:16 PM
Post: #160
Mux213 Levin GTS
mux213 Wrote:Jamie,
There are AE86 with gasket and AE86 with rings - I seen the two types in Toyota parts diagram ! First chek yours. I bought full gasket set for 4AGE bigport - these rings were included (RIKEN brand, 35EUR value for full set).
Lightbulb Deaty's GTS Project Deaty 9 5,308 04-27-2021 06:10 AM
Last Post: Deaty
  1985 Corolla GTS Project mattscar 5 10,795 01-30-2011 07:30 AM
Last Post: mattscar
  My SR5 to GTS Restoration Conversion. Lofty 15 19,944 09-25-2009 06:52 AM
Last Post: Lofty
  My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) ryceboy_124 4 22,700 08-05-2009 04:25 PM
Last Post: Eric
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 75,822 03-16-2009 10:02 PM
