Mux213 Levin GTS
10-02-2005, 10:26 PM
Post: #191
Mux213 Levin GTS
Camera is still stolen by robokill
Anyways, tomorow is MOT time!! I'm a bit worried they will give me a hard time on my seatbelts. I haven't had the time to install the ones I got from JonT and I still need the bottom metal bits for the drivers side because the previous MOT guy welded that to my body work. I did finally put the rear carpets in. Very happy with those indeed. I still need to put the new front carpet in, just haven't found the time... Anyways, keep your fingers crossed for me Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-02-2005, 11:33 PM
Post: #192
Mux213 Levin GTS
Will do...I's sure she'll pass inspection..
10-03-2005, 07:12 AM
Post: #193
Mux213 Levin GTS
Ivan, well I'm pretty sure except for the seatbelts. They have gotten alot strickter. I want to swap them for the ones that jont got for me but with the driver side mounting point being welded to my body Need to get some replacement parts first...
10-03-2005, 10:17 AM
Post: #194
Mux213 Levin GTS
CRAP!
I failed the MOT just now! The car was perfect, mechanic was very pleased with the car. But then he found some play in the steering. Turns out the lower U joint on the steering rod (the one connecting it with the horizontal bit of the steering, not sure how its called) has a tiny tiny little bit of play... So it needs to be replaced. Now for the real shocking part, Toyota has quoted me 150 euros for the damn thing!!! Well I put down the order but if someone know a place where I can get them cheaper and within a week (MOT runs out start of next week so idealy I want to replace the joint this weekend and recheck after the weekend) then I probably can cancel the order if I know by today. Damn this sucks ass!! (still I am very happy the mechanic really approved of the rest of the car, you could see he really disliked having to fail it) Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
10-03-2005, 10:22 AM
Post: #195
Mux213 Levin GTS
Auch, that's bad news!
150 euros is a lot. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop: |
10-03-2005, 11:10 AM
Post: #196
Mux213 Levin GTS
Sucks to hear that...you could try asking USN Centuri if they can get the joint for you...if they have it it will be cheaper for sure.
10-03-2005, 11:14 AM
Post: #197
Mux213 Levin GTS
Ivan, where do I find those guys?
10-03-2005, 12:00 PM
Post: #198
Mux213 Levin GTS
USN-Centuri Weversbaan 19 2352 BZ LEIDERDORP is the closest one to you (unless you prefer amsterdam).
I'll try calling their eindhoven office to check if they have the part later this afternoon. FABRICA MI DIEM, PVNC! |
10-03-2005, 12:15 PM
Post: #199
Mux213 Levin GTS
thanks mate, if you can check that would be the greatest. Give me a call when you know more..
10-05-2005, 07:12 PM
Post: #200
Mux213 Levin GTS
150 euros.........
I must say, it does look way more solid then my tiny rusty one I have now.. Gonne see if I can swap it over tonight, or maybe tomorow. Friday I go back to the MOT guy. I asked them today about an appointment, they said, when you put it on your car, drive by, we look at it, if tis good, you have MOT. So I guess they are not rechecking the car by much I'll let you guys know if my steering really improves with this. I guess its one bit less of rust to worry about (one thing though, for 150 euros, you'd think they would include the two bolts that go with it.... ) Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
Deaty's GTS Project | Deaty | 9 | 5,250 |
04-27-2021 06:10 AM Last Post: Deaty |
1985 Corolla GTS Project | mattscar | 5 | 10,757 |
01-30-2011 07:30 AM Last Post: mattscar |
My SR5 to GTS Restoration Conversion. | Lofty | 15 | 19,850 |
09-25-2009 06:52 AM Last Post: Lofty |
My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 22,672 |
08-05-2009 04:25 PM Last Post: Eric |
AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 75,452 |
03-16-2009 10:02 PM Last Post: banpei |
