Mux213 Levin GTS
04-06-2006, 06:56 AM
Post: #231
Mux213 Levin GTS
Mux,
check/change rear right brake hose. I had similar problem with my family car - just changed 8 Euro value brake line and now all is ok. |
04-06-2006, 07:08 AM
Post: #232
Mux213 Levin GTS
Mux, have you already decided which rotors are you going to buy (original, EBC, Lucas, Bradi, ...)?
Or you'll decide when you are 100% sure that they need to be replaced? Regards Andrej |
04-06-2006, 09:24 AM
Post: #233
Mux213 Levin GTS
Hey Dreja,
I bought everything, I wanted to change everything already because my rotors are getting pretty grooved but I was surprised to see how little wear there was on my other pads. I've already replaced the rear rotors, I still need to do the front. Jamie, I've had the rebuild kit for almost a year now, I just haven't gotten around to fixing the brake up. Biggest problem for me was that I have to keep my car driving and I really want to do the brake rebuild correctly and for me that means taking it off the car one day, rebuild it and put it back on another. But TE71 is going to help me out, we're going to go into a little exchange program We rebuild some calipers with my rebuild set, then change them over, then rebuild my own calipers, and he can use those. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-07-2006, 09:57 PM
Post: #234
Mux213 Levin GTS
OKay, some pictures from 2 nights ago.
First of all, this is what caused my problems: Rebuild calipers should be going in sometime next week The result was this, yes these are, or rather where, brake pads.... Nice: I just love the end result More pictures here: http://www.basenlily.nl/album/Cars/My%20...eplacement Note, the whole set: front and rear rotors plus all brake pads cost me less then 200 euro's at http://www.autopartsonline.nl I should be installing the front rotors and stuff tomorow, and next week I should be able to install new brake lines and put some new racing brake fluids in More pictures to follow! Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-07-2006, 10:20 PM
Post: #235
Mux213 Levin GTS
de tering!,kom op,snel die tollen rebuilden anders zijn deze ook zo weer gaar :wink:
sr86 completed!!........漂うことのマスター!!!! |
04-07-2006, 10:37 PM
Post: #236
Mux213 Levin GTS
OEM discs?
04-07-2006, 10:41 PM
Post: #237
Mux213 Levin GTS
That's quite cheap actually
04-07-2006, 11:13 PM
Post: #238
Mux213 Levin GTS
Jasper, dat is waarom ik rechts de oude pads van links heb gezet en de nieuwe pads in het doosje heb laten zitten
Rasteirinho, not sure about the brand, they are not Toyota OEM. Dorito, yeah I'm pretty amazed at the price aswell, I haven't found a quote anywhere under 300 E yet.. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-07-2006, 11:55 PM
Post: #239
Mux213 Levin GTS
You could probably have gotten 4 discs and 4 sets of brakepads for about the same price or less from USN centuri.. But it really doesnt matter much. I paid about the same for the front discs and rear pads as the prices on that website, and that's without the usual discount..
04-08-2006, 12:14 AM
Post: #240
Mux213 Levin GTS
Ivan, you always know better places then me
Still I found it good value for money so Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
Deaty's GTS Project | Deaty | 9 | 5,231 |
04-27-2021 06:10 AM Last Post: Deaty |
1985 Corolla GTS Project | mattscar | 5 | 10,747 |
01-30-2011 07:30 AM Last Post: mattscar |
My SR5 to GTS Restoration Conversion. | Lofty | 15 | 19,810 |
09-25-2009 06:52 AM Last Post: Lofty |
My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) | ryceboy_124 | 4 | 22,655 |
08-05-2009 04:25 PM Last Post: Eric |
AE86 Trueno Coupe (SR5-GTS)//Sweden | Allexz | 71 | 75,406 |
03-16-2009 10:02 PM Last Post: banpei |
User(s) browsing this thread: 22 Guest(s)
