Mux213 Levin GTS
08-20-2006, 05:59 PM
Post: #291
Mux213 Levin GTS
will doBig Grin
09-18-2006, 01:17 PM
Post: #292
Mux213 Levin GTS
Thanks to the 2 year anniversary drive I got a new picture of my carBig Grin
As you can see I've been very busy on my front fenders. They are currently in a new coat of paint. I also filled the holes where the blinkers where and the antenna was with fiberglass and filler.
I need to sand a few bit and fill 2 small bits that turned out not to be correctly filled with filler. Then one more coat of paint and finally finish it off with a clear coat. Hopefully it will then match the rest of the car again Big Grin
09-18-2006, 01:27 PM
Post: #293
Mux213 Levin GTS
Note,
The painting is just a cheap temp solution for now so even if the paint doesn't match up 100% I'm not stressed. I'll be fixing up my rear bootlid next and welding up some other bits. also noticed some rot above my windscreen setting in and around my filler cap so those need to be addressed.
When all that is done, and I'm satisfied all the rust of my car is fixed, I'll properly sand her down and give her a respray, but that wont be until a year or two from now..
09-18-2006, 06:57 PM
Post: #294
Mux213 Levin GTS
Muxi, if you used my guide on closing holes in wings, you wouldnt have to use filler more than one time :wink:
A good trick is painting with flat primer when you think the surface is straight. When its dry its easy to see where it needs more filler.
You can also use sprayfiller on a rattlecan.
It took me about an hour to close the antennahole (not including time for filler and primer to dry) and the result is perfect.
You remembered to use "body-kit" on the back of the fender right? If you dont, the hole will get moist and the fiberglass will sink, and you dont want that to happen Confused
09-18-2006, 08:50 PM
Post: #295
Mux213 Levin GTS
Knudsen, I know, I'm using that trick on the RX7, with the hachi it just became to late and I rushed it a bit. I thought I had gotten it right (I had already sanded that part twice) and didn't figure I had missed some after I already painted it the right color.
I did the right side fender perfect though, no signs on that fender there was ever a hole thereBig Grin
Body kit? I put a layer of tectile on the back Big Grin Moisture should get anywhere close to it Big Grin
Awell by the time its time for a complete respray of the car there is a good change I'll remove this stuff and weld in some proper metal bits anyways Big Grin
09-25-2006, 08:29 PM
Post: #296
Mux213 Levin GTS
Got myself a new little steering wheelBig Grin Steering wheel is slightly deepdishy but it actually doesn't really come much more forward then the stock wheel which is what I was hoping for.. Awell don't matter, its smaller diameter then the stock one which I'm liking already and it was cheapish. Also I got an OMP hub for the price of the cheaper one because the cheap ones were out of stock so thats pretty coolBig Grin
09-25-2006, 09:20 PM
Post: #297
Mux213 Levin GTS
Looks great! Thumbs up!
09-25-2006, 10:08 PM
Post: #298
Mux213 Levin GTS
Yup, looks cool.
Nice job on the price to. Thumbs up!
Toyota MR2 2.0 16V Gen3 Turbo
Toyota MR2 1.6 16V
09-25-2006, 10:24 PM
Post: #299
Mux213 Levin GTS
Nice
[Image: AEU86 AE86 - Mux213 Levin GTS] http://www.jdmbits.com
09-26-2006, 10:26 AM
Post: #300
Mux213 Levin GTS
Did the steering become a lot more heavy? I once drove an old corsa with a tiny wheel and that one just tried to wrestle itself out of you grip every time things got interesting.
Can you also still see the instruments in the dash?
Lightbulb Deaty's GTS Project Deaty 9 5,192 04-27-2021 06:10 AM
Last Post: Deaty
  1985 Corolla GTS Project mattscar 5 10,717 01-30-2011 07:30 AM
Last Post: mattscar
  My SR5 to GTS Restoration Conversion. Lofty 15 19,729 09-25-2009 06:52 AM
Last Post: Lofty
  My 1985 Toyota Corolla GTS Hatchback Project (2002-Present) ryceboy_124 4 22,638 08-05-2009 04:25 PM
Last Post: Eric
  AE86 Trueno Coupe (SR5-GTS)//Sweden Allexz 71 75,305 03-16-2009 10:02 PM
